foot controler
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, May 14, 2013.
  1. 29moonshine
    29moonshine
    anyone know where i can buy a variable speed foot controler. than can handle 220 volts thanks
  2. Flatheadguy
    Flatheadguy
    Curious as to the application. Depending on current use, I may have a few sources.
  3. 29moonshine
    29moonshine
    my bead roller has a 220 motor and the controler is just on and off
  4. ryno
    ryno
    grizzly in springfield mo, they have other locations too, just know where.
  5. What size motor i may have a 110V motor
    easyer to get a controler
  6. 29moonshine
    29moonshine
    the motor i have is new with a gear reduction it will roll 16 ga . i just can not control the speed
  7. sfm1951
    sfm1951
    from minnesota
    I have the same problem. Maybe its from being used to holding the gas pedal to the floor, or maybe I'm to slow. I have a Mittler bead roller. I bought a HF router speed controller but have not had time to try it out to see if it will do what i want it to. Steve
  8. 29moonshine
    29moonshine
    let me know how it works. i have watched people on utube and there roller is moving real slow, maybe i need more time rolling
  9. 35desoto
    35desoto
    Sewing machines - pinch your wife's one (if she has a sewing machine) and see how it goes. Thats what all the sewing machine co's use and the drain through the circuits is not that bad. If there is not one lying around ask at a craft shop for an o0ld sewing macine and pinch the foot control off one of those
  10. philjafo
    philjafo
    from right here
  11. Bryan G
    Bryan G
    from Delmarva
    Lots of switches, even if only typically used on 120, are rated for 220. Might need to look at the actual switch itself. I'd start with sewing machines, people give away whole units.
  12. philjafo
    philjafo
    from right here
    Sewing machine switches likely only have one switch and you would need two of the linked together to be able to control both legs of 220.
  13. Kerrynzl
    Kerrynzl
    Industrial sewing machines have a clutch and brake.
    Those crappy home sewers have variable speed controllers.
    Also look at some Bosch "industrial" hand drills for their variable speed trigger
  14. Mark Fox
    Mark Fox
