For Model A's ONLY... Rest of you "Keep Out"!!!
Discussion in 'The Hokey Ass Message Board' started by wingnutz, Nov 11, 2008.
  1. Coupe
    43.0%
  2. Roadster
    21.2%
  3. Sedan
    23.5%
  4. Other Open Auto
    3.3%
  5. Truck (Closed)
    10.7%
  6. Truck (Open)
    6.1%
  7. 1940's Era
    16.6%
  8. 1950's Era
    29.8%
  9. 1960's Era
    25.7%
  10. 1970's+ Era
    4.9%
  11. Custom
    4.1%
  12. Hot Rod
    63.2%
  13. Race (Drag/Circle/Road)
    6.2%
  14. Other (Art/Rat/Home engineered)
    4.7%
  15. 1928
    15.1%
  16. 1929
    27.3%
  17. 1930
    29.6%
  18. 1931
    28.1%
Multiple votes are allowed.
  1. need louvers ?
    need louvers ?
    283 with a Saginaw four speed behind it. I have a t-5 from an S10 here, but it mean cutting out the center crossmember and X that I built years ago to set up a mount for it. That and I have an 8" (soon to have Bronco axles) under the back, so finding a rear gear that would be overdrive friendly would be a bit of a pain, so I think that's that.
    Over the summer I plan to blow it apart, primer everything black, finish a couple of ch***is welds and wire it. I think i'm going to shorten the bed just like 4" or so, too. I'd love to have it rolling for fall when it cools enough to drive a roadster without suffering heat stroke around here.
  2. TV
    TV
    31 vickie, stock right now. but will make a few changes to come.--TV
  3. Dirk35
    Dirk35
    Tada!
    I didnt build it, but I have taken apart almost every peice of fixed them, or are fixing them.
    Whoever originally built it had great knowledge and style, just not the greatest excution.
    Only thing I havent taken apart and re-done/fixed is the body from the frame, , the cab wood, the steering, and the front suspension A Arms.
  4. EnglishBob
    EnglishBob
    C,A,C,D.
    For now
  5. wdglide
    wdglide
    Just picked up a 1930 Coupe. Plan to Hotrod it with a 283/350 maybe an S10 rearend. 3" Chop/3" Channel. Maybe some 55 Chevy parts since I have access to them.
    At least that's the plan at the moment.
    Phil
  6. englands54
    englands54
    I JUST PICKED THIS ROADSTER UP..I HAVE BEEN LOOKING FORONE FOR SOME TIME NOW..GLAD I WAITED FOR THIS GAL..SO STOKED!
    1929 roadster
    40's era
    traditional hot rod
    AND KEEPING IT THAT WAY.....
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    Sedans are of 2 distinct types, Tudor and Fordor with the Tudor being the most desireable.
  8. Jigger
    Jigger
    Won,t vote as I don,t have one but it would be cool to have a way to see the results or get
    a periodic update. At any rate, this is a cool thread!
  9. just a peek >>>>.[​IMG]
  10. IMG_0142.JPG __________________________________sedan------hot rod------late fifties era and home built
  11. glenn33
    glenn33
    from Browns, IL
    Mark,
    Go ahead and vote your preference, then every time you visit this thread you will get an update at the top of the page.
  12. Budweiser
    Budweiser
    from california
    1929 sports coupe 50"s era hot rod!
  13. bandit14569
    bandit14569
    1931 Coupe
    Hot Rod
    Custom Mods.
    50s -60s erea
  14. bandit14569
    bandit14569
    A picture explains better
  15. Morrisman
    Morrisman
    from England
    I do believe mine is based on a Model A.
  16. hotrd32
    hotrd32
    from WA
    My wife in our '29....out for a Fall drive...
    <a href="http://s614.photobucket.com/albums/tt223/hotrd32/HAMB%20Stuff/?action=view&amp;current=665843_4755020797316_2141727752_o.jpg" target="_blank">[​IMG]</a>
  17. Speed~On
    Speed~On
    1931 Coupe
    50's
    Hot Rod style
  18. jevans612
    jevans612
    Still gathering parts:
    AV8 full fendered traditional
    1928 Closed cab pu
    Banjo rear/hyd brskes
    S10 5sp
    '50 Merc flathead-.080 over - dual carbs & exhaust
    probably '35 or repro wire wheels instead of aluminum
    Trying to somewhat copy the look of this pu built by Indy Rod Shop in Ashville,NC - Ulus Burnette - builder
  19. jimbousman
    jimbousman
    Body - Coupe
    Year - 1931
    Era - Current
    Style - Hot Rod - Driver
    Full fendered
    IFS -IFS - Steelies
    Aluminum Buick V8 -T5
    Roll Back roof
    No AC - No rumble seat - no bias ply tires
  20. jevans612
    jevans612
    Sorry - pic did take on previous post
  21. d-rod!
    d-rod!
    coupe,30-31,60s,hotrod
  22. 57choptop
    57choptop
    Coupe, 29, 50s era, hot rod.
  23. Love your choice of colors on your pickup... mine was similar in color as a 60's custom but I redid it in the 70's can you tell?;)
    Wonder who'll be the guys that will be the 1928th through the 1931st voters?
  24. Rosetr
    Rosetr
    Another Roadster for us... early 60's custom hotrod style
  25. Blue One
    Blue One
    from Alberta
    I don't own a model A, but I voted anyway because I like them. :p
    And I am using a 28 A shell on my 26 RPU :)
  26. 3340
    3340
    31 roadster,v8 flathead power
  27. Pop-Rodder
    Pop-Rodder
    <----- that one right there
    '29 Roadster Hot Rod '50's - 60's style....
  28. dsiddons
    dsiddons
    from Indiana
  29. 29 special coupe,50s,hot rod
    29 roadster,late 30s,hot rod
  30. sixpac
    sixpac
    from Courtenay
    heres one from 2 years back
