Technical For Painters- Neutralize Ospho
Discussion in 'The Hokey Ass Message Board' started by JD Miller, Aug 27, 2024.
  1. JD Miller
    JD Miller
    Painters, what do you personally do to neutralize Ospho on rusted areas where rust was removed with abrasives(sandpaper etc) before primer/sealer
    After Ospho treatment, Do you wash with baking soda solution? Wash with detergent and water flush maybe some denatured alcohol(or other solvent) before primer sealer? Or just wipe down with reducer or D. alcohol?
    Or?
  2. CSPIDY
    CSPIDY
    Let it dry in the sun or heat lamp
    I’ve sanded or not and just primered directly over ospho
  3. JD Miller
    JD Miller
    Primed right over it with what? rustoleum or alkyd enamel paint?
    I dont thing you are supposed to do that with a epoxy primer or any auto primer .
    I think the Ospho label kind of says to do that... I know it says to scrub off the grey/white residue and wipe down with solvent first before painting over
  4. 31Apickup
    31Apickup
    The SPI epoxy website states to neutralize, if dry reset with ospho and let set 1-2 minutes, then with a clean rag and water, wash off like washing the car and dry. Next DA with 80 grit, clean with wax and greas remover, let dry an hour then shoot epoxy. On miscellaneous yard stuff I just apply ospho and paint over it with rustoleum no issues.
    klleetrucking likes this.
  5. K13
    K13
    The only people who can answer this question with any sort of meaningful response is the manufacturer of your primer.
  6. JD Miller
    JD Miller
    Posted about "Neutralizing" Ospho techniques ...................... not about primers or manufacturers . Thank you
  7. K13
    K13
    Neutralizing is meaningless if the primer manufacture doesn't allow it's use or the use of acids under their primer. And you did talk about primers when you said you didn't think automotive primers could be sprayed right over it.
  8. JD Miller
    JD Miller
    WTF. Get lost
    winr likes this.
  9. Bandit Billy
    Bandit Billy
    I have used both Ospho and Rust Mort in the past. The Ospho must be wet to neutralize it. If dry, just spray it down with water (I use a spray bottle from the dollar tree) and wash it like you wash your car with clean rags but no soap. Dry it when done and then I hit it with 80 grit DA then thinner or reducer (whatever I have left lying around to clean it) and spray epoxy primer. Never had an issue.
  10. CSPIDY
    CSPIDY
    Tow Truck Tom likes this.
  11. KenC
    KenC
    It doesn't require neutralizing. But, if there is any white grainy deposit on the surface it needs to be sanded clean. Or you can wash it off, I just don't like water on bare metal that I'm working on,
    Some epoxy makers don't recommend applying over any acid product, SPI being one. Others like my choice, Kirker, is fine with it and even sell their own acid based metal prep..
    I've used a lot and never any issues doing it that way.
  12. Kiwi 4d
    Kiwi 4d
    So it seems if you have bare bright steel and want to stop rust forming a light coat of ospho, let it dry fully and when you are ready paint over it. Cleaning with water on a large item like a ch***is would be very difficult to avoid trapped water and flash rust.
    NEW METALS
    For new Ferrous metals, remove dirt, grease, and oil, apply OSPHO ni a thin coat, let dry for a minimum of 24 hours, then apply paint. Longer dry times may occur depending on temperature, humidity, and over-application of product. Adry, powdery, greyish-white surface usualy develops when cured. Brush of any loose powder and wipe down with Mineral Spirits before painting. OSPHO penetrates deep inside of the metal's pores ot convert and protect before Iron Oxide si present.
    winr and alanp561 like this.
  13. I’ve done it this way with “rust converters”on flimsy panels we didnt want to blast like roofs and hoods. And some floors that were heavy pitted.
    Strip the panel to bare metal. Clean as much rust as possible from pits. (3m black stripping wheel)
    Apply the rust converter per instructions.
    DA the panel with 80-180. Per primer instructions.
    Prime as normal. In theory the converter handles the small areas you cant reach.
  14. Fortunateson
    Fortunateson
    Good point!
    Tow Truck Tom and Outback like this.
  15. clem
    clem
    wow !
    what a way to treat someone trying to help you….…….and others that may read this thread………
    37slantback, Bugguts, fauj and 11 others like this.
  16. gnichols
    gnichols
    from Tampa, FL
    Indeed.
  17. winr
    winr
    from Texas
    What if one was to use a spray bottle to get OSPHO into a cab where the inside/outside and drip rail are spot welded together ( 3 layers ) .... or inside the opening of the upright posts ( hollow ) ( left and right ) support the windshield and roof ??
    What I am meaning is places you cannot sand or brush away deposits ??
    I have never dealt with this before on all the vehicles I have painted
    Perhaps it would help the OP as well
    Ricky
    JD Miller likes this.
  18. KenC
    KenC
    It's not ideal, but when I need to deal with this I use a blow gun to remove excess Ospho before it dries. That way there isn't (or shouldn't be) any of the white grainy stuff to remove. Then I apply a LOT of epoxy primer, spray, pour, brush or whatever is needed to cover everything and soak into lap joints. And the first coat of epoxy is overthinned to help with the lap joint part.
    winr likes this.
  19. Budget36
    Budget36
    FYI, K13 is in the business.
  20. Doublepumper
    Doublepumper
    from OR-WA, USA
    I'm literally on the beach and use Ospho on everything. Never neutralized it and never had any problem with it in many years of use. I spray it and then wipe it with a cloth. This will help it dry evenly, eliminating any chunky buildup. I scuff it with a red SB pad, wipe it with prep and go.
  21. 54chevkiwi
    54chevkiwi
    Water neutralizes it. Sounds counter intuitive I know, but the phosphoric acid has already etched it by then and the water doesn't rust it. You get that bluish/orangey type tinge in the metal, that's your coating. Do about a section the size of a door at a time. Not in the sun
    Stay away from acid etch primers or epoxies that adhere by acid etching ... Ppg shopline epoxy says not to put over metal conditioned steel from memory, check the data sheets. Use an epoxy urethane, spi epoxy is perfect
    winr likes this.
  22. 53choptop
    53choptop
    winr and Budget36 like this.
