For the engine builders- 1955 Ford 272
Discussion in 'The Hokey Ass Message Board' started by Thunder Road, Aug 19, 2008.
  1. Thunder Road
    Thunder Road
    I need some opinions about installing piston rings.
    When I put them on the pistons I aligned the ring gaps like this:
    (using the clock face)
    oil spacer 12:00
    one oil rail 11:00
    2nd oil rail 1:00
    lower comp ring - 2:00
    top comp ring - 10:00
    Then after the pistons were in the holes, I read that the rings should be spaced 120 degrees apart.
    I'm thinking they ought to be pretty close, but I never like to leave the gaps below piston centerline.
    QUESTION... should I go back and set the gaps at 180degrees- or leave it alone?
    It's now or never... what do YOU think?
  2. On a 3 ring piston I use the 180* spacing never leaving the top ring at the bottom of the cylinder. So I start with the top ring in the top of the cylinder,12 0-clock, and work down from there>>>>.
  3. Mr. Creosote
    Mr. Creosote
    Ive always set them 180 apart along the center line.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Do be aware that rings slowly rotate in the groves as the engine runs. On 3 piece oil rings I have always spaced the ends of the rails about 90* away from the spacer joint. But now it's together I would not loose any sleep!!
