??? FOR THE OLDS GURUs
Discussion in 'The Hokey Ass Message Board' started by droplord49, Feb 13, 2006.
  1. droplord49
    droplord49
    from Bryan, Tx
    I am swaping out the hydro in my 55 Olds for a 700r4 using a adapter from Bensteins. My question is, since I am losing the rear, side motor/****** mounts and the front motor mount is a center mount. When I put the 700 in there and it only has a center mount am I going to have problems with the motor trying to tip from side to side when accelerating? Should I fab up a center crossmember too and make side mounts like the factory ones were? There are two holes in the bottom of the belhousing adapter that I could make two bisket style mounts off of if needed. I know I have seen some straight sixes that only have center mounts on the motor and the ****** but I didn't know if I can get away with it on a V8. Thanks, Dustin.
  2. oldcarfart
    oldcarfart
    do not even fire it up as is, a minimum 3 point triangled mount is minimum for axial stability.
  3. Paul
    Paul
    Editor
    I used a pair of HURST front mounts and single trans mount on my 394/Muncie combo.
  4. Gotgas
    Gotgas
    from DFW USA
    Yes, definitely. You need to make a more positive engine retention system than that with any engine, but Olds V8s are notoriously torquey.
    Torque-straps are really ugly though. Just find another way to mount it if you can.
  5. droplord49
    droplord49
    from Bryan, Tx
    Thanks guys, that is what I figured, fabing up some side mounts won't be a problem, just thought I would ask.
  6. OldsGuy
    OldsGuy
  7. brawler500
    brawler500
    from Roxbury NJ
    I made up some side mounts for my 394 and used the single front mount. Your idea to pick up holes in the adaptor sounds good to me.
    David
  8. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I would have to agree, when I did my 55 Olds with the SBC I used modified 57 Chevy mounts and a single mount for the TH350...was smooth when it was running, didnt lurch or bounce around.
