Technical FOR THE PAINTERS
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Jun 13, 2026.
  1. Bandit Billy
    Bandit Billy
    ^^^^What he said! That is what I am after. Fun, patriotic, sparkly
    Sharpone, guthriesmith and Moriarity like this.
  2. Budget36
    Budget36
    My kid has a 2019 Impreza. It’s white and has a “sparkle/metallic” in it. She was hit on the side and it was resprayed and the shop nailed it. It’s like you mentioned, when the light hits it right, you can see the glimmer in it.
  3. Bandit Billy
    Bandit Billy
    Panels in 400. Smooth as a gravy sandwich like Mark says.
    I adapted my body roller to hold them where I can shoot em easy. . And no, I didn’t screw them on, there are mounting holes in the bottom so it just slips over the wood screws for easy hanging.
    I’ll seal and base coat them both in the morning as soon as the Shop hits 70 degrees. Then the fun part.
    I need a shower.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    No test panels?? Right to the main event?
  5. Bandit Billy
    Bandit Billy
    I have a test panel set up to test the red and blue. Yes silver is a given
    RMcCulley, SS327 and Sharpone like this.
  6. DDDenny
    Like putting model cars together as a kid, only looked at the directions if there was some kind of "failure to communicate".
    alanp561, SS327, X-cpe and 1 other person like this.
  7. Bandit Billy
    Bandit Billy
    Reading the directions adds valuable time to any project. I can’t understand most of them anyway.
    alanp561, SS327 and Sharpone like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    for painting candies you want a small fan pattern maybe 6-8" at the most. wide fans have little control at the outsides. You need to hold the gun fairly close, maybe 10" and be parallel to the panel and never at an angle. 50% overlap p***es and walk the length of the panel
  9. Bandit Billy
    Bandit Billy
    I am planning on using my jamb gun on the candy red and the transparent blue, it has a nice tight pattern and those areas won't require a lot of paint so the small cup should be fine. I have a good base gun for the sealer and silver base, Iwata for the clear coats. I would really like to not have to cut and polish this. I figured hanging them will help in keeping dirt out.
    I wish they were hanging right side up for ease of laying out the flag. I just came up with an idea on that. After I base them, I could remove the top 2x4 and move it down the uprights, mount the 2x4s wide side horizontal (toenail it) and use a bungie cord between the two panels on top to hold them upright. I need to go buy a couple short bungies. Having them upright would aid laying out my pattern. I could do it with them laying down but it's much harder to see what I am doing, and upside-down sounds like something Roth would do after reading @Ryan 's post about his website. :cool:
    Budget36, SS327 and Sharpone like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    it is always a good idea to paint things as they are seen on the car so that the parts that show get the proper attention.....
    dogwalkin, Sharpone and Bandit Billy like this.
  11. JD Miller
    JD Miller
    Nice concrete driveway work , Exposed aggregate etc :D:D
    Bandit Billy likes this.
  12. Bandit Billy
    Bandit Billy
    I'll do a quick remodel on the stand.
    Sharpone and Moriarity like this.
  13. Bandit Billy
    Bandit Billy
    Nice as long as you keep it sealed! My buddies dribble all over the place when they stop by...and their cars are worse. :cool: 20 years here and I don't have oil stains on my drive, and I own a flathead and an Olds! Drippy sum*****es! That damn olds would drip oil in the middle of Antarctica with the crankcase empty!
    kls50, RMcCulley, alanp561 and 4 others like this.
  14. ronzmtrwrx
    ronzmtrwrx
    “My father was an Oldsmobile man.” ………:cool:
  15. hotrodA
    hotrodA
    That’s cuz your wife won’t let you guys use the guest bathroom! :eek: Mine is the same way.!:rolleyes:
    alanp561 and Bandit Billy like this.
  16. Bandit Billy
    Bandit Billy
    Nice catch!
    When I had the urinal installed she said it disgusting. I asked if she preferred the guys using the house baths or "watering" her yard and she warmed to the idea.
    dogwalkin, alanp561, SS327 and 4 others like this.
  17. Bandit Billy
    Bandit Billy
    I thought about those pics all night and I was about to ask you if you put the silver flaks down first and shot transparent colors over the top. I went back and re-read (I'm not sure I read it the first time as I was consumed by the pics), and now I see that is how you did that. So you put just enough clear to bury the flakes and sand it and that also allows for the masking of the pattern. I like this.
    SS327, 427 sleeper and Bentrodder like this.
  18. Bandit Billy
    Bandit Billy
    Time for an update, ya think? Panels flaked, cleared and wet sanded to 400 IMG_8747.jpeg
    Today I cut out dozens of stars. They look traditional but they are “In motion” weaving in the breeze. Some are left oriented and some are right. They were a PITA to draw and cut out
    Here’s the lay out.
    I motor imaged the flag on the other side, both leads with blue and tail with stripes.
    this evening I covered the panels and prepared to spray the transparent blue over my stars.
    to my pleasant surprise the making paper held beautifully. I was careful to time the removal of the masking paper carefully, exactly one crown and diet (short gl***). They came out perfect!
    All masking removed and ready to tape off the silver and blue and lay down the candy red tomorrow. It’s going to be warm so I need to get out there early. I put a lot of motion in the stripes so they are going to be a pain to mask.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
  20. Bandit Billy
    Bandit Billy
    Thanks for putting up with the calls mate. Outside my comfort zone but catching up.
    Now...how the hell do I get all the metal fake off my garage floor? :cool:
  21. Sharpone
    Sharpone
    You don’t You clear coat the floor
    Dan
    Robdski, 427 sleeper, X-cpe and 9 others like this.
  22. big duece
    big duece
    from kansas
    I would be worried about the shoe traffic transfer into the house... that stuff gets everywhere.
    Nice work!
    427 sleeper, alanp561, SS327 and 2 others like this.
  23. Sharpone
    Sharpone
    Looking Kool :cool:
    Dan
  24. Bandit Billy
    Bandit Billy
    I found some flake in the master bath today. That is a long way from the garage. My wife made me strip naked in the back yard and took my paint clothes to the “Bandit washer”. The machines she keeps in the dailies garage so her stuff doesn’t end up with garage filthy (and glitter evidently).
  25. guthriesmith
    guthriesmith
    Looking good Billy!
    Bandit Billy and Sharpone like this.
  26. chopolds
    chopolds
    from howell, nj
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    tell the wife it isn't metalflake it is glitter from the last time you had strippers over....
    427 sleeper, RMcCulley, GuyW and 10 others like this.
  28. big duece
    big duece
    from kansas
    It will be hard for him to finish his project when he's in a body cast
  29. Sharpone
    Sharpone
    My wife made me strip naked in the back yard.
    Like Mark says you got it made:rolleyes:
    Dan
  30. Bandit Billy
    Bandit Billy
    to have the red painted here today and prep for clear.
    Thanks. Hope
    And it don't rot your teeth!
    She called it stripper glitter. Asked if I had a pocketful of ones on me. I told her more like a bag of loose change.
