Technical for those that have done the model A to 39 trans swap. A question.
Discussion in 'Traditional Hot Rods' started by Hitchhiker, Feb 16, 2014.
  1. Hitchhiker
    Hitchhiker
    What throw out bearing do you use? V8 or model A. seems like it would need the A stuff....Yes, I have emailed the manufacturer. Hoping to get a answer soon.
  2. Hitchhiker
    Hitchhiker
    I think my problem is I need a v8 clutch diaphragm.
  3. youngrodder1929
    youngrodder1929
    I cut my model A fly wheel down and used a v8 clutch and throw out bearing
  4. olskool34
    olskool34
    You do not need the v8 clutch. The stock A pressure plate, disc and all is used. The only thing I found that I needed was the v-8 universal cover "clamb shell", all 3 pieces. I know you are having a problem with the throw out bearing but if you could post a pic, it would help. This was a rather straight forward operation for me so I think your problem is something simple.
  5. olskool34
    olskool34
    Here is the pic showing where I had to notch the adapter because of the dropped spring.
