Looks great. BTW where the hell is all the snow? Looks like you guys have less than we have had so far.....
bad*** truck..yblockss..hell yeah...oh they fit alright.i went to a junk yard and got a crossmember with mounts and we welded that in.and my frames pinched almost three inches.to get my 292 in.backed by a 3sd od from a shoebox ford...what trans you using..rearend..ill post picts of mineif i ever develop them.
Good looking truck. I am wondering if the engine is a tad too far forward? Looks like the fan is going to be where the radiator should be. It just may be the angle the picture was taken. Jim
Shifts & Bones- I take some details of the frontend in the next day or two. The basic is model A axle with split 34 1.5 ton truck bones. A de-arched reversed eye spring from Posie mounted behind the axle attached with 5 degree perches from TCI. That is all mounted to a 2X4 1/4 inch channel welded below the front cross member looks pretty good.
Ratster & Kart- The ****** I am using is a from a early 80s mustang. Aluminum case 4 spd with 4 gear being an overdrive. The were drilled for both a large and small bolt pattern for mounting. So I am using a stock bell housing and a 5/8 inch spacer plate I had machined up to back the transmission up with, because the input shaft is longer than a stock trans by that much. Like the idea of the 4 spd and a overdrive to boot. Had is around from an old project. The rear is a stock 56 ford rear with limited slip (some speed catalog part from back in the day lock the side gears up) with 3.93 gears.
JimC- Ya its a an angle thing and the fact that the front cross member is so wide.. The radiator is about a inch away form the fan just like I like them. The radiator will be sitting inside the shell not to the back edge of the crossmember.
sounds very cool....i have a truck bellhousing that at some time in the future mines gonna get a mustang t5 most likelly after i thrash the 3sd od....i bet you'll be pertty happy with the results of a nice " modern" 4 speed trans behind that y...keep us posted.
hi lucky im puttin 292 in mi 30 sedan bin lookin for 4/5 speed for mine {petrol over here £0.80 per litre} your truks on themoney dude but is the box an auto or stick if stick where dose the stick place comperd to seat? regards keith
