Technical Ford 1935 headlight clips assembly
Discussion in 'Traditional Hot Rods' started by A-Y8, Jan 20, 2016.
  1. A-Y8
    A-Y8
    from Sweden
    I forgot how the headlight clips for the reflector was mounted.
    Does anyone have a picture of how the clips should be installed ?
    Thanks
    Johan
  2. Happydaze
    Happydaze
    Nope, but I can tell you that some of the re-poped clips are wrong (bent the wrong way) and require modification (easy with pliers) on the '36 so there's every chance these are the same as the problem you may be having?
    Chris
  3. A-Y8
    A-Y8
    from Sweden
    No, they have been installed before...
  4. A-Y8
    A-Y8
    from Sweden
    I figured it out, thanks anyway Chris!
