Technical Ford 1937-41 spindles
Discussion in 'Traditional Hot Rods' started by jdcool44, Nov 22, 2019.
  1. jdcool44
    jdcool44
    Are there any pros or cons to using OEM ford 1937 to 41 spindles vs reproduction other then having to drop the steering arms?
  2. Fordors
    Fordors
    If you have early spindles and the bearing surfaces on the stub axles are good then I’d prefer to use them provided you have access to an oxy/acet torch to heat and bend the arms. Round backs can be found for $150 or less, a savings compared to new spindles and bolt on steering arms.
  3. jdcool44
    jdcool44
    I do not have any yet . Just priceing I do have access to a torch at work and a good vise.
  4. Mr48chev
    With the oem Ford units you can be ***ured that they were made with the correct and quality steel and not a mix match of melted down s**** that may have been a lot better for forming into rebar to put in concrete floors that you might possibly see in some made in China units.
    Side note, I bought a chromed set of oem ones off Ebay a while back thathe someone cut the stock steering arms off and welded on arms made of flat bar that they heated and bent to shape. Those will never p*** inspection here and are getting cut off and replaced with bolt on arms that I bought at the swapmeet last spring from a guy who had upgraded to shiny ones.
  5. treb11
    treb11
    If you have any question about the integrity of the spindles, take them to a machine shop for a magnaflux inspection. Cheap insurance.
    Sent from my SM-G965U using The H.A.M.B. mobile app
    26 T Ford RPU and Just Gary like this.
  6. Prewar steel was of far higher quality than what is made now.WW2 used up the reserve of high grade ore.I can only guess at the standard the Chinese use.If you don't want to bent the arms they can be cut off,and bolt ons used in their place.
  7. Just Gary
    Just Gary
    The HAMB is all about traditional hot rodding.:cool:
    Modifying stock parts to suit our needs is the very foundation of traditional hot rodding.
    What other justification do you need?:confused:;)
    oj and alchemy like this.
  8. jdcool44
    jdcool44
    Just making sure I get the right parts the first time. Dont have a lot of extra money to be buying parts twice for one reason or another. I do think the stock arms dropped looks better. I will be buying orignal soon.
    Just Gary likes this.
  9. OE spindles are by far superior quality even after all the time that's p***ed since they were manufactured. Ford didn't skimp on his metallurgy and the prices for usable original parts are still reasonable. I tried to convince a friend to go that route but he ended up buying new aftermarket ones, the bores for the king pin bushings were reamed too large right out of the box and the bushings would slide right out just from gravity pulling on them.
