Technical Ford 2100 Carb Question
Discussion in 'The Hokey Ass Message Board' started by El Caballo, Nov 29, 2020.
  1. El Caballo
    El Caballo
    from Houston TX
    This is the carb off of my 1963 Galaxie 500. The car had a rebuild kit that came with the purchase, the car ran but the car idled at about 1,200 and the carb wouldn’t kick down. It made loading the car on a trailer exciting. That aside, I pulled the carb off, soaked it and then rebuilt it today.
    I think someone tried to fix the carb a very long time ago, couldn’t get it to run right and gave up and let it sit. It was registered last in 2005.
    I think I know why, it appears that the throttle plates are binding and I can’t figure out why. The plates only fit in one way and the rod they bolt to doesn’t bind. I tried installing the plates in different ways but like I said, they only go in one way. As you can see, the adjustments are way out of spec.
    Has anyone else run into this? It doesn’t much matter as I have a Holley 4 bbl and an Edelbrock aluminum intake that I will install after I completely replace the brake system. I was just hoping to test the brakes under its original engine configuration before diving into the engine and possibly doing a cam change as well.
    The first four pics are the before pictures.
    43E737F4-EE44-43F0-95FD-C95527DD6A34.jpeg 47A58942-B957-4E10-A210-E1ACF35BA616.jpeg 7D1F93F4-3C59-4E8D-9D7F-55D694B90DEA.jpeg 598517A1-D68D-4950-9D96-646CC9244687.jpeg CDC615CD-5E84-4EDA-85E5-17DA5C2DBDC6.jpeg A25A3284-DFFE-48AF-9004-5842DFC0A51B.jpeg D9FBEBC6-5A40-4ECE-9B44-10CE40BA5F74.jpeg 36A06D57-928F-44FC-8B2D-6BE7A4D0935F.jpeg
  2. Well, one of the throttle plates is upside down; the little 'nubs' should both be showing the same way. Pull them out, then re-fit them without the screws. One way they'll completely close, the other way they won't. Reinstall the screws once you find the right way, but don't tighten them until the throttle plates are fully closed; that will properly align them. Double-check after tightening. Do put some lock***e on the throttle plate screws.
  3. Truck64
    Truck64
    from Ioway
    I've got a 2100 that is otherwise a stellar carb it idles perfect, at ~600 RPM, but try to idle down much lower than that (factory engine idle spec of 450-550), it tends to bind as well.
    Kind of annoying. Interesting to learn that an adjustment of sorts of the throttle plates is possible @Crazy Steve but I'm a bit leery to try that, might make it worse? They "look" good when holding up to the light.
    deucemac likes this.
  4. deucemac
    deucemac
    Listen to Steve, I rebuilt boat loads of them when I worked for Ford and we did exactly as he said. An excellent, dependable, and simple carb that Ford used up until fuel injection took over.
  5. big bird
    big bird
    Things that you have to watch for are wear in the shaft bores and **** in the air bleeds for the idle.
    Other than that, a drunken monkey could rebuild them blindfolded and they will work fine
    Truck64, Boneyard51 and deucemac like this.
  6. Mimilan
    Mimilan
    I don't know about drunk.
    lake_harley and tubman like this.
  7. seb fontana
    seb fontana
    from ct
    Doesn't the throttle shaft look fat? I haven't had one of these carbs in my hand but I remember shaft dia being close to 5/16", the one in that carb looks way bigger.
  8. seb fontana
    seb fontana
    from ct
    Video pretty good!
  9. Boneyard51
    Boneyard51
    It’s too late for this carb, but I rarely take the plates out of a carb, just for this reason. They are a little difficult to get back in just right. The way to do it is just like Crazy Steve said. Make sure the idle speed screw is backed way out so that you can the throttle plates as low as possible in the bores with out binding. The p,at es won’t “ spin “ in the bores as they are somewhat oblong. Those are some of the best two barrel carbs made.
    Bones
    Truckdoctor Andy likes this.
  10. El Caballo
    El Caballo
    from Houston TX
    Steve, I did as you said and it worked perfectly, hats off to you sir.
    Truck64 and 61Cruiser like this.
  11. El Caballo
    El Caballo
    from Houston TX
    Boneyard51 likes this.
  12. Beanscoot
    Beanscoot
    That carb doesn't look corroded, so the throttle plates must have been held open by either the idle screw or the choke (fast idle) linkage.
    57Custom300 likes this.
  13. Glad to help....
  14. Beanscoot
    Beanscoot
    Looks like you need to fix the broken screw on the power valve cover (or ignore it if it's not leaking):
  15. tubman
    tubman
    I really liked the way the monkey put the wrench back at the end of the video.
  16. El Caballo
    El Caballo
    from Houston TX
    I have to ignore it for now, the previous owner snapped the head off of the bolt. I tried extracting it but to no avail, so I rtv’ed it and the gasket. Seems to be working out well and not leaking. I have a Holley I’m going to replace it with anyway. The car runs like a champ now, I wish I could post the video.
