Technical FORD 223 HELP
Discussion in 'The Hokey Ass Message Board' started by Nos1partstore, Aug 1, 2021.
  1. Nos1partstore
    Nos1partstore
    I just bought this 55 f100 that had been sitting for probably 15 years. I hooked some wires and a 12 volt attery to it and it spins freely, however I have no spark. I then cleaned the contact and gave the contact a little more gap, but still no spark. I replaced the coil with one from my running Flathead but still no spark. What are yalls recommendations. I am willing to replace anything necessary. See picture for what I have
  2. inthweedz
    inthweedz
    Are you using the original wiring??
    Have you tried a jumper wire direct from the battery to the coil??
    Have you got power to the coil, then thru to the moving arm of the points??
    Earth wire in the distributor no broken??
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. BJR
    BJR
    Not your starting problem, but isn't a 55 Ford 6 volt positive ground, thought they went 12 volt in 56. Swap in a new condenser after verifying you have power to the coil.
    sidevalve8ba likes this.
  5. Nos1partstore
    Nos1partstore
    sounds like doing the full 12volt conversion may be the right choice
