Ford 223 - noisy
Discussion in 'The Hokey Ass Message Board' started by TBUCKETMILLER, May 4, 2011.
  1. TBUCKETMILLER
    TBUCKETMILLER
    I have a 223 Ford in my 1960 F100. The lifters sound like they are coming through the side cover. Is this normal? Is there a way to make this engine less noisy?
  2. I thought they had solid lifters in the 216/223s?
  3. TBUCKETMILLER
    TBUCKETMILLER
    I am not sure on the solid lifters but I have heard that as well. If that is the case how can you make the noise go away or be less? Maybe it is the valves making the noise. I haven't tried to set the valves to .019 yet.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Solid lifters and, at this point, probably worn rocker arms.
  5. forty1fordpickup
    forty1fordpickup
    Is the top end getting oil? Everything gets real loose and noisy if it isn't. You will hear it coming from 1/2 a mile away. Years ago I had two that I installed external oil lines to oil the rocker arm shaft.
  6. 59Custom300
    59Custom300
    Mine was a little noisy, sounded like a tractor motor. It seemed to be running OK.
  7. Adjust your valves, then let us know how it sounds.
  8. 56 ford custom
    56 ford custom
    from Socal
    like what was previously posted. Adjust your valves.
