Hot Rods ford 223 rockers
Discussion in 'The Hokey Ass Message Board' started by uglyjesus, Feb 8, 2025.
  1. uglyjesus
    uglyjesus
    from Ohio
    need some advice....i have 1 set of barker hi lift rockers(6) and cant find another set
    i also have 5 fenton hi lift rockers, i could never find anothere1
    if i just use the barker set should i put it on intake or exhaust side?
    everything is stock
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I use higher ratio rockers on the intake sometimes.
    jimmy six likes this.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    Since the 223 uses a shaft mounted rocker setup, the ratio for all rockers must be the same. Try reaching out to Rocker Arms Unlimited in Redding, CA. They make aluminum rockers for many applications, and may be able to complete your set
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Couldn't you just move the pushrod cup/ball location a smidge on whichever set you want a different ratio? And then string them all on the same shaft?
    sunbeam likes this.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    This all depends upon the amount of ratio change between the rocker sets, and how they were designed. The locations of valve tip, pivot shaft, and push rod are constant, and so define the rocker ratio. Truly high ratio rockers should have been originally supplied in a full set (12) and included offset towers. If the length between the valve tip and pivot shaft were kept constant, and only the push rod cup moved closer, the change in ratio would have to be very small. My guess is about .05
  6. uglyjesus
    uglyjesus
    from Ohio
    thx ...does any1 out there have 6 barker rockers for sale?
