ford 223 Trans?
Discussion in 'The Hokey Ass Message Board' started by kyot4x4, Nov 24, 2012.
  1. kyot4x4
    kyot4x4
    What transmissions will bolt up to a ford 223? I have the 3 speed but im sure there are other ones that will work.
    Kyle
  2. greaseyknight
    greaseyknight
    from Burley WA
    With this adapter you can put a T-5 from a Mustang in there http://www.ford-y-block.com/truckt5.htm
    Also various 4 speeds of the era will work, not sure on the specifics maybe someone more knowledgeable can chime in. The basics is that the 223 does not share a bolt pattern with anything else, however the bell housing bolt pattern should fit a more common trans. Caveat, you won't get lower rpm's on the freeway as top gear on 3 speeds and 4 speeds is direct or course you will get a better spread of gears which helps alot in town.
  3. kennkat
    kennkat
    There is a "granny Box" 4 speed that came in pickups, Top loader style...
  4. kyot4x4
    kyot4x4
    Thanks for the info.
