Projects Ford 272 rear sump can u face to to the front?
Discussion in 'Traditional Hot Rods' started by Cmore, Jun 23, 2015.
  1. Cmore
    Cmore
    from Wisconsin
    Just bought a 272 and it has a rear sump is there a way to switch it to the front without hurting anything. Putting it in to a 1956 fairlane
  2. RichFox
    RichFox
    Not checked out on Y block Fords. But Y block Lincoln truck engines have the rear sump. To use the p***enger car (front sump) pan you must also use the oil pickup that goes with that pan.
  3. synchro7
    synchro7
    Any Y-block pan with oil pick up tube (239,256,272,292 or 312) 54-62 Ford or Mercury will work except, T-Bird, pick up, or big truck.
  4. Cmore
    Cmore
    from Wisconsin
    Ok Thanks. synchro I will be looking into That thanks
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Post this over in the 52-59 Ford Social Group,someone might have the parts you need,if the donor y-block came from a truck there is a little more you will need to know.
    Rob68 likes this.
  6. d2_willys
    d2_willys
    from Kansas
    Reversing a Y block pan should be pretty simple, but the bolt holes are the issue, along with the pickup tube entrance. If you rotate the pan 180 degrees, the pickup tube entrance is now on the p***enger side. You will need to block that opening and cut a new one on the driver side where the sump is. If the bolt holes do not line up you can either drill new holes, or make an adapter plate that bolts to block and has tapped holes for the pan.
  7. dan c
    dan c
    didn't the great majority of these engines come with a front sump?
  8. I think front sump pans are more plentiful than rear.
  9. warbird1
    warbird1
    All the p***enger cars except the 'Bird came with a front sump pan... just find one of those along with the correct oil pickup tube and you're good to go.
  10. RichFox
    RichFox
    Most people are looking for rear sump pans to put the engine in an early car. The OPs pan is probably something somebody wants.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Tri-Five Chevy's are rear sump,could you imagine the looks you would get with a y-block under the hood? :rolleyes: :eek: :confused:
    warbird1 likes this.
