Ford 300 I6
Discussion in 'The Hokey Ass Message Board' started by JCook5003, Jun 16, 2008.
  1. JCook5003
    JCook5003
    Hey Guys,
    I am looking at pickup a 1981 F150 truck for a donor for my T-Bucket build.....
    I want to go with a short frame, duece grill, and tall skinny tires.....
    That truck has a 300 I6 and a 4 speed which I think might be a T170 4 speed overdrive.......
    So a few questions, anyone have a pic of a t with an I6 in it, and anyone know the length of a 300 from fan to bellhousing mounting surface?
    Also how hard is it to install a manual into a T, me thinks 3 pedals may be a little cramped if so I have a C6 laying around that should bolt right up.....
    Anyway just looking for opinions and insights.
    Thanks
    Josh
  2. duste01
    duste01
    Thats what the red baron is. theres a few pics around here, they are pretty cool.
  3. AnimalAin
    AnimalAin
    A C6 is overkill behind a 300; a C4 will hold the power, is smaller, lighter, and has less power absorbtion. In a small car like a T, these issues are even more important. If you want to gear the rear end for dig around town, an AOD will work, as well, but you will pay more for the extra gear.
  4. JCook5003
    JCook5003
    Yeah I have a buddy with a C4, I am considering using a 2wd toyota rearend which will most likely be greared at 4.10
  5. The_DropOut
    The_DropOut
    I'll let my friend know about this post, he has a 240 I6 and I understand that the 240 is identical [exterior] to a 300 I6.
  6. sko_ford
    sko_ford
    heres dakota's its a chev 292 but you get the idea
    and a for the third pedal i go with an asen double or a f1 xross member and pedals under the floor
  7. Ebbsspeed
    Ebbsspeed
    There have been a couple of "Red Baron" cars built by different folks. The "original" car won the Oakland Roadster show, has a Pontiac OHC six (not a Ford 300I), and currently resides in the Speedway Museum in Lincoln, NE
  8. JCook5003
    JCook5003
  9. tjm73
    tjm73
    300 Fords are tough as nails. You will never hurt it.
    Every question you could possibly have on the 300 can be answered at http://fordsix.com/forum/viewforum.php?f=2&sid=5779ba975d6f7a2a972d63a59427f2e7
    C6 is overkill, but if you have it, use it. I'd use the 9" that the truck has in it, but narrow it a little. Super tough and all parts are available everywhere.
    As for rear gears, the 300 has a ton of torque down low so 4.11's are not needed. It'll work very well with something in the 3.25-3.50 range. Also FRPP sells a wide ratio ge****t that would be a great upgrade.
    I say use it. I like 300's.
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    240/300 is one of Ford's best engines - they are damn near bullet proof. I'll second (or third/fourth) the C4 trans - the trans tunnel to clear a C6 will intrude on precious interior space.
  11. 39sledge
    39sledge
    i run one in my hot rod they are pretty tough.
  12. Yeah, TJM73 nailed it. Go to fordsix.com and check out French Town Flyer's stuff. Mighty impressive.
    Another vote for the C4.
  13. JCook5003
    JCook5003
    Cool thanks for the help so far guys.....appreciate it, anyone else?
  14. I'm putting a 300 bored .60 over in my 47 ford truck. I found a rebuilt c4 cheap. I'm a huge fan of the 300. My daily driver has one in it. I won't buy a new truck just because they don't offer it anymore. If you still need to know the length of the motor I can take measurements tonight
  15. JCook5003
    JCook5003
    Yeah Harkins those measurements would be good, if you dont mind, my donor is about an hour away
  16. junkiegene
    junkiegene
    from anaheim
    Go to Fordsix.com, or something like that. Its out there, I have it in my favorites as Ford Six Preformance 240/300 There's more info than you need there.
  17. tjm73
    tjm73
    I already provided a link to the best place to get the info you are seeking. But here's a direct link to the FAQ for the Big Six 240/300. it contains a lot of info you should know about the 300's.
    http://fordsix.com/forum/viewtopic.php?t=11348&sid=799d23cda6ae50f169c971d19e63043a
    Since you seem to not want to do your own research, even when I give you THE place to look and learn, and I recall this off the top of my head, it's about 36-37" over all in length. That's roughly fan to bellhousing mount.
  18. 39cent
    39cent
    from socal
    most any tall gear with a 6 in a T will work. They got TORQ. Don,t need no OD.
  19. Fordman75
    Fordman75
    The 300 is a great engine. And it makes more torque then a 302!:D
    Here's some pics:
  20. tjm73
    tjm73
    Not entirely correct. Yes it makes more torque in lower RPM's. But the 302 make's 300 ft-lbs in 5.0 Mustangs while the best 300 made 265 ft-lbs. I believe standard 302's in mid 90's F150's made around 280 ft-lbs.
  21. Fordman75
    Fordman75
    I never said a stock 300.:D
