Projects Ford 300 l6 Good,Bad or just plain Ugly
Discussion in 'The Hokey Ass Message Board' started by The Blurr, Jun 16, 2009.
  1. The Blurr
    The Blurr
    I was looking for some thoughts on a Ford 300 straight 6. I am thinking of puting one in a 1940 ford pickup and running without a hood. I have always liked a straight 6 I like the sound, the look so on and so on. I want a Ford 6 because I am kinda a stickler as far as keeping a ford motor in a ford car and chevy motor in a chevy. So is this a good bad or just an ugly idea. Lets hear what you have to say.
  2. 64 DODGE 440
    64 DODGE 440
    from so cal
    If ya want it, do it. Good strong engine with lots of grunt.
  3. Snarl
    Snarl
    Best engine Turd ever made. Also the longest. You'll probably need to notch the firewall to get it in there. Make some measurements before you spend any money...
  4. budhaboy
    budhaboy
    I say go for it - beauty is in the eye of the beholder, and quite frankly, I am always amazed at the power some people can coax out of a straight 6.
  5. Sphynx
    Sphynx
    from Central Fl
    And theres a great after market selection for them clifford builds a nice four barrel intake and header set for them and cams hell go for it .
  6. kwoodyh
    kwoodyh
    I love the 300 Ford! I'm not sure what you're going to have to do to get it to fit though? It is a very long engine and the engine compartment of the 40 may be a bit cramped? I'd do some measuring before diving into the project head first! Clifford makes some speed equipment, I think??? Building the 6 will be more than a small Chevy though!
  7. Jonesey
    Jonesey
    The 300 I6 can be good motor for dependable driving and good torque, just don't expect alot of horsepower. We have one with nearly 300K miles on it and it still runs good, I just wish the transmission could last that long.
    For a good compromise I went with a 302 in the '56. Good torque and horsepower in a small package, and parts are 350 chevy cheap.
  8. Mr48chev
    Great engines, that are strong and reliable but I don't think it is the right thing to put in a 40 pickup with no hood. If you go ohv a Y block would be the best looking just for appearances sake and a 302 or 351 would probably be the best fit for reliable performance.
    Sometimes having an engine sitting in a rusty old Pickup out behind the shed isn't always the best reason to put it in certain vehicles.
  9. zimm
    zimm
    from iowa
  10. Ak Millar sure liked 'em. His ran a turbo and used propane.
    Like has been said, gonna be a tight fit.
  11. CJ Steak
    CJ Steak
    from Texas
    With just basic bolt-ons it's a pretty peppy motor and can give a 302 a run for it's money if it's geared right. If you want to spend quite a bit more and do some homework you can build a 300 like the one I did years ago that I shifted at 7000 RPM and had a full roller valve train in it.
    You CAN do pretty cool stuff with a 300. I got the biggest kick out of beating guys with built V8's. It was worth the price to be the freakshow on the street to me, but it may not be to you.
    The biggest hurdle is that cylinder head. Start looking at larger valves, and if you run a high lift cam and need higher valve spring pressure, you'll need to install screw in studs to keep from pulling them out. They're pressed in from the factory. PM me if you want build details or tips on how to build a strong 300. I've built several of them at different performance levels.
    Best of luck, and BTW my daily driver is a '95 F150 SWB Reg Cab with the 300-6 and an M50D 5 speed with 3.73's. I pulled home a '67 MGB GT at 80mph in overdrive with the A/C on max with a bed full of parts and got 13mpg this Saturday. The truck has 233,000 original miles on it and has never had the transmission replaced, or the valvecover/oilpan removed from the engine. 300's are stout.
  12. art.resi
    art.resi
    Why no hood??? Great engine. I got a ticket in Atascadero Ca. for no hood on my 52 ford 2 door in 1959. Was showing off my newly installed 303 olds.
  13. The Blurr
    The Blurr
    I hear what your saying. A Y block would be cool I was just trying to think out of the box (but there may be a reason why it is not in the box) And there is not a old rusty pick up behind the shed I was looking at buying a rebuilt one. Like I said I like straight 6's but I wanted to stay with a ford motor. I will probably get shot for this but there is a rebuilt 58 371 olds in it now with a zepher trans. I was planning on pulling and using in something esle. I was thinking of using it but I do not think this is the right motor either.
  14. choppintops
    choppintops
    Never used one in a rod, but had plenty in trucks. Great motors.
  15. The Blurr
    The Blurr
    You know, I do not know. When I look at the truck in my minds eye that is how I see it. I usually do not like no hoods either. But I am just going with it. I can always put it back on.
  16. Bulletproof motors with tons of low end grunt. Doesn't the frenchtown flyer run one?
  17. The Blurr
    The Blurr
    Haha! The French Town Flyer sounds like a crazy sexual postion!
  18. art.resi
    art.resi
    Agree with that. I put mine back on after that ticket. I am amased how
    much people get away with now as in example no fenders open exaust
    no hoods. I used to get nailed in the 50s and 60s all the time for that.
    Wouldn't mind that 371 olds. Had a 40 ford pickup with a olds once.
  19. Kenneth S
    Kenneth S
    And guys with 426 hemi's, boss 429's, and other V8's didn't want to race against Ak's 300 6!
  20. And you want to hear a really cool exhaust note? Boy, that thing howled!!!
  21. mtkawboy
    mtkawboy
    Ran one in an H/G 51 Anglia back in the early 70s. Forged F600 crank & rods, Kay Sissell head, Holman/Moody 4 barrel intake with 600 Holley. You can use a late F150 injected one with real nice factory manifolds like headers. A 302 bellhousing bolts right up for a 4 speed. Just not sure it would look right in your application. Bulletproof motors though. Not fast by todays standards but it ran 11.60s back then. Hybrid V8 heads ruined the class
  22. The Blurr
    The Blurr
  23. 39 Ford
    39 Ford
    I have a freshly rebuilt one in my 1985 Bronco (2000 mi in the past 2 months) they run great but on upgrades I have to downshift guite a bit more than I would do with a V-8.
  24. oldebob
    oldebob
    from Spokane WA
    My buddy has a Comp. Eliminator "Wally Trophy" in his living room won with a 300 six. His did have a homemade Boss 302 V8 hybrid head. As I recall it ran in the 8.6 range in his altered roadster in the late 60's. One would be a tight fit in a '40 PU I think. They are one tough engine though.
  25. Do it, I had a 240 in an f100 and I think it was the best motor I have ever had.
  26. Retro Jim
    Retro Jim
    First Thank You for keeping a Ford in a Ford !
    They are great , strong running engines ! I am sure there are some good speed parts for them also ! The best straight 6 Cly I know of .
    Just remember they are very long so measure to make sure it will fit first .
    So what are your intentions with the Ford 300 ?
  27. Retro Jim
    Retro Jim
    I wouldn't say too modern ...but just way different !
    A SBF would be a lot easier ! Just a thought !
  28. Bettlejuice
    Bettlejuice
    from WV
    Came out in 65 in, of course, pick-um-ups... They're TOUGH, I had a couple friends in high school that beat the livin' shit outta some nice bodied 80's F150s. My old man had one in a late model F150, 2x4 short cab long bed, and it was sorta weezy I thought. But thats in the southern PA/northern WV mountains, and I'm used to the 4-cam 5.4L in my Lincoln lumberin' merrily along in OD.
    <i>EDIT: Oh yeah, interesting 300 trivia, they rolled off the lines at the Cleveland engine plant... You can say you have a Cleveland (I have/had numerious 351Cs, thats how I know this... Just saying "I've got a Cleveland" gets some respect, you don't even have to say the size :) )
  29. Heres the one in my roadster, good engine and really dosn't look out of place.
