Hot Rods Ford 302 engine builders
Discussion in 'The Hokey Ass Message Board' started by MCooke, Jul 27, 2024.
  1. MCooke
    MCooke
    I have a 1971 TVR Vixen with the original straight 6. I am planning on changing that to a Ford 302 with aluminum heads as that will be about 60lbs lighter than the 6 that’s in it now. I have T5 gearbox and posi dif so all set with that.
    So I am looking to buy a turnkey carbureted 302 with the aluminum heads and a decent cam for street use but with that old school sound. I don’t need or want any more than around 300hp as the car only weighs 1,800lbs.
    I am in the north east and would like to find a company that could supply this if possible in my area although not opposed to shipping either. The web is full of companies but would appreciate any suggestions from forum members. Thanks, Martin
  2. Turns
    Turns
    You do know this is the hamb ?
    Budget36 likes this.
  3. Mr48chev
    You will want to delete the year as you are asking about a Ford engine builder and not about a specific car. Maybe just say TVR coupe and leave everything else off.
    You might want to see if there is a Mustang meet close and ask the guys with slightly modified small blocks there. Get the same answer with positive reviews a few times and you have probably found the go to shop.
  4. The37Kid
    The37Kid
    Check to see if Mike Pet*** is still building engines in New ****ord. His Dad had a Griffin that was Ford powered.
  5. Beanscoot
    Beanscoot
    Maybe move to Off Topic Hot Rods...
  6. GordonC
    GordonC
    Try Mike Forte at Forte's in Waltham M***. They do a bunch of Ford engines of all sorts. He is supposed to be a real helpful guy. At least the Cobra guys think so.
