Ford 302 problem
Discussion in 'Off Topic Hot Rods & Customs' started by PeggySue, Oct 21, 2025.
  1. PeggySue
    PeggySue
    Found my zero compression source. After taking off the intake manifold I decided to hook up the compression gauge and try it again. While cranking and still no compression I felt air escaping out of the valve port of the zero cylinder. I put my hand over the port while cranking and was getting a alternating ****ing/ blowing out of the port. So probably valve, will pull the head tomorrow.
    loudbang and Johnny Gee like this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Solid or hydraulic lifters?
  3. PeggySue
    PeggySue
    pretty sure there hydraulic
  4. PeggySue
    PeggySue
    Update. Pulled the head did a leak test with head out. The zero compression # 2 cylinder had a bad intake valve leak ran out as fast as I poured the water to the valve , #4 also had slow leak. So now deciding rebuild the bad one and leave other or put new in both.
  5. gene-koning
    gene-koning
    If one head has 2 bad valves, how good can the valves in the other head be? You are only a head gasket away from doing it right. I would pull the other head and either buy a good pair, or have both of your heads rebuilt.
    ottersea, PeggySue, ALLDONE and 3 others like this.
  6. ALLDONE
    ALLDONE
    X2
    PeggySue likes this.
  7. PeggySue
    PeggySue
    Yes thank you that is the plan. I'm wondering to the heads have roller rockers with hydraulic flat tappet lifters, not roller from what I researched that shouldn't be done.
  8. chicken
    chicken
    from Kansas
    Roller rockers can be used with flat tappets with no problems. Been done forever, long before the roller tappet became commonplace. It's crazy how bad information keeps propagating.
    SS327, ottersea and PeggySue like this.
  9. PeggySue
    PeggySue
    Yes thank you, I see that after searching more on the topic.
  10. RmK57
    RmK57
    Wouldn’t hurt to inspect all the tappets for wear while you have it that far apart.
  11. gene-koning
    gene-koning
    If you pull the tappets to inspect them, do one tappet at a time. I's very important that each tappet returns to the valve in the cylinder it was broken in at. Do NOT mix them up if you intend to reuse the cam or the lifters.
    PeggySue and SS327 like this.
