Has anyone here put together a Ford 330 motor to a T5 Transmission. I know there are adapters that can do it for upwards of $500. I am on a low budget as we all are, and am wondering if any other bellhousings with slight modification could do the trick. Any help is appreciated! Thanks for your time. -Pete
Take the bellhousing you have,set it on the floor and then put the t5 up on it . Then see what needs done to make it work.If you know a good machinist he can help you with rest of it. The center hole is important,the rest of the bolt holes just need relocated. Hope this helps... Rob
