Ford 351W 0 Miles
Discussion in 'Parts For Sale' started by fcarnut, Jan 2, 2023.
  1. fcarnut
    fcarnut
    City: La Verne
    State: California
    Price: 3200
    This is a motor I built and was going to use for a project but decided to build a 302/347 stroker instead. Block is a '72 cast with '70 Heads. Here are some of the details:
    Comp Cam 270 H10 and lifters, Trick Flow 3/8 hardened push rods, Comp Cam true roller rockers, hardened seats and double springs, 3/8 ARP rocker studs, Edelbrock valve covers, Cloyes double roller timing set. Block is is fresh .060 over, King main bearing (.010 under), Clevite rod bearings (.010 under), Speed Pro Hyper pistons with Hastings Molly Rings, Melling Std oil pump with hardened drive shaft, FelPro Gaskets, Edelbrock dual plain intake with Edelbrock carb. that will need to be rebuilt or replaced. Stock distributor with Pertronics igniter modual. New 8mm Blue Streak wires. New Mr. Gasket high performance water pump, New fuel pump and Royal Purple break in oil.
    On test stand for you or your agents inspection. Sorry, NO shipping. $3200.00 obo
    No low Ballers. No Trades! Can help load into your truck. Does not include any part of my test stand which include: Exhaust system, flywheel, starter, bell-housing, coil, MSD ignition modual or Alternator.
    If you can read the ad it is still available. 9 zero 9 5 nine 3 zero 6 six nine Leave message. Calls monitored for spam. NO TEXT. Land Line Listed in several locations
