Hot Rods Ford -36 pickup frontfender geometry?
Discussion in 'The Hokey Ass Message Board' started by Hebster52, Oct 25, 2015.
  1. Hebster52
    Hebster52
    Been trying to find out some info about how to make sure that the horseshoe frontfendermounts get the correct shape.. Is there some sort of blueprint or drawing with dimensions anywhere online that could help me form them correct?
  2. Budget36
    Budget36
    I suppose you don't have them?...or are you trying to fix bent ones?
    Either way, I have a spare set in the shop, will try to measure them out for you.
  3. I have not been able to find one . At one time I had 4 of them , none of them had the exact same shape I made a template of what looked the best . Then made a matching pair . I am finding that fitting the front fenders is not to easy
  4. When doing front fenders of Ford or Chevy that use under fender braces I've learned to hang and fit fenders and get contour and fender flange corrected and matched to each other. Then make the fender brace fit the fender and headlight bar. Doing a brace first just seemed to create a battle I didn't want to fight.
    The Wizzard
    31Vicky with a hemi likes this.
  5. Hebster52
    Hebster52
    Thanks. I have them for both sides. Both the braces and fenders will need a lot of work. Not yet compared the braces to each other.
