Hot Rods Ford 390/406
Discussion in 'The Hokey Ass Message Board' started by 49merc, Dec 28, 2024.
  1. 49merc
    49merc
    from Kansas
    Is there an external difference between the 390 blocks and the 406 blocks (i.e. do they share the same motor mount design and will the blocks interchange in the frame using the same mounts?).
    Thanks for your help.
  2. deathrowdave
    deathrowdave
    from NKy
    Same , later blocks have two sets of motor mount bosses
  3. Beanscoot
    Beanscoot
    I believe some high performance 406 engines had cross bolted mains, those bolt heads are evident externally.
    Deuces and Boneyard51 like this.
  4. No changes. The two are direct nut and bolt interchange in every way.
    lemondana and Deuces like this.
  5. 2devilles
    2devilles
    All the blocks have the earlier bosses on them, so all will work.... If you're going from a later style block that used the later bosses to an earlier one, it might not work (later blocks have early and late bosses). But 90% use the early bosses, so all blocks will work that way...sorry, got a few beers down, hope that made sense.
    arse_sidewards and Deuces like this.
  6. That is not the case on 406. That is a 427 only motor. The 427 is still an FE motor casting and will bolt in the same place as the 390-406 motors but no 4 bolt main is not found on the 390-406 units.
    arse_sidewards and 2devilles like this.
  7. Flatrod17
    Flatrod17
    My 406 has all the boss's for crossbolts, just not drilled. I also have a early 390 HP solid cam only block that has boss's cast in too. I have caps that I can make either a crossbolt block, but don't think I will bother. Early blocks are 2 bolt motor mounts, starting in 65 they went to 4 bolt motor mounts.
    Deuces likes this.
  8. Boneyard51
    Boneyard51
    No 406s were cross bolted from the factory.
    Bones
    Tow Truck Tom likes this.
  9. Boneyard51
    Boneyard51
    The main difference in the 390s and the 406 was the diameter of the bore! 4.050vs 4.130. Cylinder wall thickness comes in to play , here. Various FE blocks, while identical on the out side( save the engine mounts) were different on the inside! Sometimes even the same cubic inch engines were different on the wall thickness! One of the biggest “ problems “ with building an FE!
    And the FE was known as a thin wall casting engine!
    Bones
    alanp561 and Deuces like this.
  10. Pontmerc
    Pontmerc
    from Finland
    Older pre 64 blocks might not are thin walls.
    This is just a rumor.
    I know for personal experiment that 64 352 is a thin wall casting.
  11. Beanscoot
    Beanscoot
    This guy named Pat Ganahl thinks some 406 engines had cross bolted main caps, but hey, what does he know?
    And how do you prove a negative?
  12. I knew of a Pat Ganahl and he did a lot of writing and a lot of research. However, there isn't any Long Distance service long enough to reach him so I can ask him where he got the info he printed. I'm sure he got it from a reliable source however our incoming President often says the same thing and I don't always agree with him either. I'm still waiting on my return call from Trump. If you or anyone else can find a crossbolt main 406 I'd pay to take a look at it with its pants down.
    1952henry and Boneyard51 like this.
  13. patsurf
    patsurf
    :):):):D:D
  14. Boneyard51
    Boneyard51
    As an old FE fan, think since 1959, I am a member of sevral FE forums. A lot of information is now at hand on the net. Many current FE gurus warn about misinformation in some of the older books. Back in the day, when I was building FEs , these books where about to only information available, other than a persons own experiences.
    There is more information and parts available, now, than when the FE was still in production!
    I still have all my old books on FEs, but in today’s world, there is more current information available!
    Bones
    Okie Pete, Deuces and arse_sidewards like this.
  15. jnaki
    jnaki
    Hello,
    A friend bought a new 1963.5 Ford Galaxie with a 406 motor. It was supposed to be the Ford equivalent motor power to compete with the Chevy 409 motors. It came close in some semi-factory cars with big name drivers/builders, but for most on the street, it was close, but not faster than the Chevy 409 sedans.
    upload_2025-1-18_3-48-27.png A similar look, low mean sounding and somewhat fast. Our friend purchased it at the local Mel Burns Ford dealership.
    The newly purchased Ford Galaxie looked great, all black, with black rims and a small set of center hubcaps. The motor sound healthy and had power. The 4 speed was nice, too. In the summers, when it got hot the 4 windows got rolled down for cooling and now, the exhaust/+ motor sound were amplified to the point of little conversations at low tones. Ha! but, at least we were cool in more ways than one. YRMV
    The owner just happen to have a new 18 foot Howard Speed Boat being built with another 406 Ford motor with a set of fancy chrome headers and a single 4 barrel for reliability. It was his stepping forward for his hobby of water skiing. It was certainly fun to put the "metal to the pedal." The Parker Dam location for our water ski adventures was on smooth waters and it was a fast, gl***y run each time out on the water.
    Jnaki
    The sedan was fast with the new motor. It was Ford’s step in the right direction in the “more power” game of factory stock cl*** cars. But, in comparison to our friend’s 409 Biscayne, there was no comparison. The 409 had more definite power and thrust upon full acceleration. So, any comparison and compe***ion at the local drags was not a future with the 406 motor set up. Unless you were Les Ritchey or Gas Ronda and the full factory backing for “stuff.”
    Note:
    Within a year or so, the step in the right direction was taken by the Ford Motor Company. The 427…YRMV
    1952henry and 41 GMC K-18 like this.
  16. stuart in mn
    stuart in mn
    The great thing is you can tell everyone the 352 in your car is a 406 since they look the same. ;)
    Okie Pete, Deuces and winduptoy like this.
  17. sidevalve8ba
    sidevalve8ba
    I've heard all kinds of stories about how much you can and can't bore an FE. Can anyone set me straight on that?
    Boneyard51 and Deuces like this.
  18. Bore it until you hit water, then back off .030".
    Okie Pete and unforgiven like this.
  19. finn
    finn
    Some claim the FT truck versions have thicker walls than the equivalent FE car engines.
    There are some things to address, though, if using the FT block, like the distributor hole is larger so it has to be bushed. The cranks are steel forgings instead of castings, but the snout is larger and has to be turned down to work with a car damper.
    Okie Pete and Deuces like this.
  20. When in doubt do a sonic test after cutting .030. We used to be able to get .060 pistons for 390's and never have a problem. I had a 427 block that was a worn .040 over and was used up. Do some homework before you start cutting. Best insurance policy you can buy.
  21. sidevalve8ba
    sidevalve8ba
    I had always heard that .030 over on a 427 was about the limit.
    SOHC427 and Pist-n-Broke like this.
  22. birdman1
    birdman1
    I bought a 1958 332 interceptor block that sonic tested .23" walls and has the bosses for cross bolt mains. I also had a 1962 406 engine I. My 1962 galaxies that was a side oil blck. Had the bosses for cross bolt mains
  23. Boneyard51
    Boneyard51
    Yes I can! Sonic test the block you intend to bore and let that guide you! The only true way to be safe!
    Bones
    Okie Pete likes this.
  24. Boneyard51
    Boneyard51
    The Ford FE engine is a great engine that FoMoCo came out with in 1958, it continued till the seventies. During this time various cubic inch engines could be bought, from 332 to 428. The blocks have very similar outward appearance, but through the years the blocks were cast differently and with different features. They were also cast in different foundries. This is why it is difficult to give one answer about the FE. Then throw in the FT, a very similar engine used in trucks. It lasted longer than the FE, with Ford building them for U-Haul, long after Ford quit building FEs.
    But in the FE world, it is considered to bore the very least amount that will clean up the bore. Also Sonic check every block, before the bore job. There are some blocks that are considered stronger than other block. There are certain variations in some series that are considered stronger than more desirable. There are also different versions of what is generally considered the same cubic inch engines. There are some rare and experimental blocks out there.
    To me this just makes the FE more interesting, to others, it indicates an engine to avoid.
    I built a lot of FEs back in my prime, while never thinking I was an expert, I considered myself, at least knowledgeable . Later as there became a revival of the FE and info on the internet, I’m not sure I could have considered myself at the “ knowledgeable “ level. But with all the gurus sharing their knowledge, information is just a key tap away!
    Bones
    deathrowdave and vtx1800 like this.
  25. coupe33
    coupe33
    I am into my first FE other than a 60 T-bird I had as a used car when I was a teen. The 60 was ok the problem it had was over heating probably a from a overbore. I am getting back into them because of a project 57 Ford 2 door sedan Custom 300 that I just started. I bought it out of a s**** yard. I bought a second out of a different yard for parts. 1964 T-bird is the donar with a 390 automatic. Looking at the interior will fit and it is better than the 57,s . At least one more month before the body goes back onto the frame. 6 months in.
    Boneyard51 likes this.
  26. EL MOE
    EL MOE
    I have a cam out of a 1966 390 fairlane GTA don’t know if it’s different from a stock cam I figured anybody who looks at this post might know it’s free to a good home thanks
    finn likes this.
  27. F-ONE
    F-ONE
    from Alabama
    FEs are indeed amazing engines. If a 352 sits in an old Galaxie long enough, it turns itself into a 390 Interceptor or if it stays in there long enough as sale day comes, a 406.
    It happens in the shop too....
    That old 352 from an F100 turns into a 428 just sitting in the corner.
    Heck even 360s turn into 352s on sale day.....
    Imagine that.
    '40 Coupe Fan likes this.
  28. finn
    finn
    Should be the same cam the 428 Cobra Jet used.
    PM me if it’s still available. The 390 in my ot 67 Mustang has some sort of boy racer rumpety rump cam that burns my eyes from all the hydrocarbons it p***es through the exhaust, and I’m contemplating going back to a stock cam to remedy that.
  29. cabong
    cabong
    Boneyard51, loudbang and J. A. Miller like this.
  30. J. A. Miller
    J. A. Miller
    from Central NY
    Wins on Sunday, sells on Monday!!
