Ford 390 help
Discussion in 'The Hokey Ass Message Board' started by ten thumb, May 4, 2009.
  1. ten thumb
    ten thumb
    from texas
    Changing the harmonic balancer on a 64 Galaxy and was wondering why the old one had that rod sticking out of it. What is it for and do I need to move it over to the new one?
  2. 390Merc
    390Merc
    from Indiana
    I've removed several in the last few years from 64-63 Galaxies and never saw any such thing. Maybe somebody stuck the rod from the cam in their sometime while being it was being worked on years ago.
  3. Baron
    Baron
    I would think not. It serves no purpose that I can think of. Does it stick out of the front side at all?) Possibly a dowel pin that was used to align a second pulley....?)
  4. DirtyThirty
    DirtyThirty
    from nowhere...
    Does it line up with any timing marks???
  5. ten thumb
    ten thumb
    from texas
    No it dont line up with anything. And the timing marks are etched on the side. Damn thing got me stumped. Guess we will just install the new one like it is. Thanks.
  6. 58custom
    58custom
    That rod is NOT original. Forget it.
  7. There is a chance that someone installed that when the engine was balanced. ***uming that it has been rebuilt.
  8. Bettlejuice
    Bettlejuice
    from WV
    Nope, shouldn't be there, I just ran down stairs and took a look at mine to double check and there's nothin' there. I don't even know why someone would put it there, unless they had an extra pulley on the front of the motor.
  9. I would think it has something to do with balancing. Has the balancer been lightened at 90*?
  10. lippy
    lippy
    from Ks
    Thats the magnet for the optional M-code magnetic crank trigger ignition!! Sorry J/K. :D Leave it out.
  11. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Perhaps someone's attempt to keep the damper from spinning on dry-rotted rubber?
  12. squirrel
    I've seen dowels like that used for balancing (that's why dampers have all those holes), but it looks like it's slipped out most of the way?
