Technical Ford 390 starter problem
Discussion in 'The Hokey Ass Message Board' started by willys36, Mar 27, 2016.
  1. willys36
    willys36
    I have a '64 Ford 390 that used the long nose starter, but I think all 390s bell housings came with the bulge for that starter. I have to a mini starter but the one I got has a smaller diameter gear with 9 teeth. The original starter has 9 teeth also but a bigger pitch and bigger diameter. My guess is I have a 164 tooth flex plate. I don't want to pull the engine if I don't have to. Does anyone make a mini starter for the earlier flex plate gear?
  2. e1956v
    e1956v
    Alliance Vendor
    What brand of mini starter?
    Can you post a pic?
  3. Jalopy Joker
    Jalopy Joker
    where did you get the starter from?
  4. ididntdoit1960
    ididntdoit1960
    from Western MA
    you will have to change the flywheel to the later style if you want to get away from the "pull" style starter
  5. Yep, that's more fallout from the trans/bellhousing change Ford did in '65. You'll need a '65-up flywheel and I believe the matching bell, but you'll need to check that to make sure the starter is in the right place. The later bells don't have same 'bulge' as the early ones.
  6. willys36
    willys36
  7. willys36
    willys36
  8. mammyjammer
    mammyjammer
    from Area 51
    I have one of his starters on my FE, high quality, great instructions, great tech support!
