4-speed Ford Toploader (Tremec) transmission with Jeep top shifter (NOS) with Lakewood Scattershield (dual drilled for Ford or Chevy transmissions), 392 Hemi steel flywheel w/ pressure Plate and disc, clutch arm and throughout bearing, hydraulic slave cylinder With mount. I don’t have the adapter plate, but this is available from Wildcap and Other sources. This is the overdrive version of this transmission, but you can put the regular gears in this case which has been clearanced for the Jeep shifter. I am pricing this just based on the value of the Jeep top shifter, which is new, plus the Chrysler steel flywheel, pressure plate, disc, etc. (all parts are quality new......used for mock-up only) Call Tom @405-447-4591
