found a real nice 1941 ford sedan body,can i fit 48 front fenders hood and grille with too much fittings???? thanks for your times!!!
I would think you would be able to. A lot of the 40's custom 41 fords were updated with later 42-48 sheetmetal. Your front axle is narrower though, so your track width might look narrower also. You'll need all the inner fenders, splash pans, fender mount etc from the donor 48 too. 41's are different. Matt
I'm pretty sure the frame horns at the front are a little different too but you can probably make things work.
