Hot Rods ford 427 question
Discussion in 'The Hokey Ass Message Board' started by rodnut, Sep 4, 2015.
  1. Jalopy Joker
    Jalopy Joker
  2. coilover
    coilover
    from Texas
    Built a 64 Falcon Futura HT with a warmed up 427 and an Alston full tube ch***is. Nasty little ride with unbelievable tire plant. Even with a 10 point cage it would twist the windshield opening till the gl*** pulled far enough out of the rubber to see light through. My partner had a 67 Cyclone GT with the single 4bbl 427 that was a strong runner.
    hendelec and lothiandon1940 like this.
  3. An Alston full tube ch***is would twist enough to seperate the gl*** from the seal??? You need to get your money back.
    The Wizzard
    gimpyshotrods likes this.
  4. c6me is a 1966 mercury block , c6ae is a 1966 ford galaxie or full size ford
  5. A 63 block will read c3ae but impossible to tell if 427 , unless it is cross bolted , if not crossbolted measuring the bore is the only way
  6. Jalopy Joker
    Jalopy Joker
    current ad: sacramentocraigslist.org/PTD/5160025352.html - Craigslist>Sacramento>For Sale>Auto Parts>by dealer - Ford 427 Side Oiler Engine
  7. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Just bear in mind that FE blocks had tapped holes in the side of the block that can be mistaken for cross-bolt holes. These were for block-mounting fixtures used for ***embly and weren't drilled through the block's side skirt, but a good machine shop can drill out the holes and bore into/thread the main caps. So, as the others noted, check casting numbers, bore/stroke, whether solid- or hydraulic-lifter, and other little clues for the oiling system (oil filter adapter, for instance).
  8. gimpyshotrods
    gimpyshotrods
    You got that right.
    If this isn't an exaggeration, this ch***is is dangerously built wrong.
  9. rodnut
    rodnut
    from indiana
    Thx for the info , my engine has bolt that appear to be the cross drilled mains and also bolt holes above those which could be the holes you described . I'm going to post some pics tomorrow and see what people think . You mentioned the oil adapter what's the deal with that
  10. rodnut
    rodnut
    from indiana
    Post-n-broke ! I don't think the little old lady I bought it from gives refunds lol
  11. moefuzz
    moefuzz
    c3ae 6015 indicates = 63 Large body/Galaxy -the 4th letter (E) indicates engine/accessories -(E stands for Engine/and/or/engine related part/***emblies).
    It came from a 1963 Galaxie 500XL. Check your bore for actual displacement.
  12. moefuzz
    moefuzz
