Ford 430 oil/vacuum pump
Discussion in 'The Hokey Ass Message Board' started by 55chieftain, Jan 23, 2010.
  1. 55chieftain
    55chieftain
    At our shop we've recently pulled apart a 59 430 for a rebuild. At one point someone has removed the vacuum pump and tube from the oil pump . I'm looking for a source for the vacuum pump and tube. Kanter only listed an oil pump and Egge didn't even list a 430, any other ideas? I would like to put it back together the way it should be with the vacuum pump back on the bottom of the oil pump. Thanks in advance. Bill
  2. weathrmn
    weathrmn
    Are you sure there a vacuum pump combined with the oil pump? The vacuum pump was combined with the fuel pump on the early Ford engines
  3. 55chieftain
    55chieftain
    Yes, this vacuum pump wasn't for accesories like vacuum wipers, it was more of a crankcase evacuation pump, but the shop manual calls it a vacuum pump. It's shown in the shop manual, I don't have a copy right now to post the pic.
  4. 58Lincoln
    58Lincoln
    Try Chris Dunn at Lincoln Land In Clearwater, FL. ph# 727-446-2193
    He's a good guy and knows his stuff.
