Technical Ford 460 in F100
Discussion in 'The Hokey Ass Message Board' started by Circa*, Mar 25, 2014.
  1. Circa*
    Circa*
    from Montebello
    First post in a long time. I have a 62 Unibody F100, 460 ford out of 1974 Thunderbird and C6 Transmission. Has edelbrock carb, recently transmission was rebuilt. Now as soon as I drive and hit 60 mph the engine hesitates and will not accelerate more. I have tuned carb thinking mixture might be off, what else should I look for what else can it be?
    Thank you in advance.
  2. Canus
    Canus
    Have you verified that your throttle linkage is allowing the carburetor to fully open?
  3. castirondude
    castirondude
    Check your fuel pressure (while driving). If you're ****ing air (before the pump) or have a clogged filter it will do that.
  4. Circa*
    Circa*
    from Montebello
    Thank you both will check and come back to inform.
