ford 8 in ???? finding drums
Discussion in 'The Hokey Ass Message Board' started by sawbuck, Apr 9, 2009.
  1. sawbuck
    sawbuck
    from 06492 ct
    i have a 8 in rear 57 inches non tapered housing..2.00x10in.brakes..cant find drums.. the center hole of the drum is 2.75 in. all the drums at NAPA are 2.5 in. center hole.....tried mustang, comet,maveric.... help what do i have here ???thanks
  2. Lowbuckboz
    Lowbuckboz
    Try an 84,83 LTD 2.
  3. hotrod-Linkin
    hotrod-Linkin
    have you tried granada??
  4. gearsforguts
    gearsforguts
    from temple,pa
    try 77 comet/maverick,i think those have the larger center hole
  5. hotrod-Linkin
    hotrod-Linkin
    this is 77 granada..might help,maybe not.<TABLE cellSpacing=0 cellPadding=3 border=0><TBODY><TR vAlign=top><TD vAlign=top></TD><SCRIPT language=javascript> function ViewImage() { var imgSrc = (do***ent.getElementById('PartImage')).src; var newWindow = window.open(imgSrc, 'popup_win', 'width=450, height=450,toolbar=0, location=0,directories=0,status=0,menuBar=0,scrollBars=0,resizable=1'); newWindow.focus(); } function SetImage(obj) { var imgUrl = obj.options[obj.selectedIndex].value; var imgTag = do***ent.getElementById('PartImage'); imgTag.src = imgUrl; } </SCRIPT><TD>[​IMG]</TD><TD>Item#: UP 6401240
    Price: $104.00
    tax and shipping not included
    Disclaimer: The stated price may vary from the in store price and may change at anytime.
    Attributes:
    Features & Benefits:Castings Meet SAE J431/G3000 Specifications For Proper Tensile Strength.
    Features & Benefits:Machined To Control Perpendicularity & Run-Out For Optimal Performance & Brake Life.
    Features & Benefits:NAPA Brake Drums Are Vehicle Specific & Meet Federal Safety Standards.
    Product Features:NAPA Brake Drums Provide Consistent Quality & Reduced Noise.
    Drum Type:Brake Drum
    Mounting Type:A
    # of Bolt Holes:5
    Bolt Circle Diameter:4.500"
    Inside Diameter:10.000"
    Maximum Discard Diameter:10.060"
    O.D.:11.700"
    Brake Drum Surface Depth:2.360"
    Height:3.460"
    </TD></TR></TBODY></TABLE>
  6. mazdab2600
    mazdab2600
    4 or 5 bolt?
    83 ltd 10" is 2769r and 4 bolt.
    76 granada 10" is 2671r 5 bolt
  7. 32SEDAN
    32SEDAN
  8. sawbuck
    sawbuck
    from 06492 ct
    it is 5 bolt... that NAPA site gives every thing but the center hole diam.
  9. lakes modified
    lakes modified
    Try 73 9" cougar drums. They are super wide. They fit the 8" axles & you can use 2" shoes.
  10. sawbuck
    sawbuck
    from 06492 ct
    stll looking ,thanks all
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I got part numbers for ya..and they are common cheap drums..I believe ranger truck drums..I have the same rear end in my A and found the original drums were cost prohibited..way too pricey..I think i got mine for 28 bucks each they look a bit different than stock but they work
    lemme go out and see what the number on the box is
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ok ive got all kinds of numbers for ya..
    I got these at Car Quest
    have them look at these numbers..Im not sure what one is the part number so you may have to go down the list with them until one hits
    8923
    RB112W
    FL405
    8923BDR
    900968
    im sure one of those will be a direct hit
    I ran into this problem last year..this is how i soved it..Ill send you a Pm to let you know
  13. Von Rigg Fink
    Von Rigg Fink
    from Garage
    8923BDR is the CQ #..Im having my parts guy chase it and give me a price and what they come off of
  14. mazdab2600
    mazdab2600
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
  16. mazdab2600
    mazdab2600
    not 100% sure on the ranger.
    my frame and rear for the 52 is off a 79 f150/ranger.doh!
    hang on. i'll measure mine. its 10" rear.
    :eek:forgot.
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah my friend has an F-150 with "ranger" taged on it..its even a pot metal emblem..than the mid size ranger came out after ford imported the courier(sp)..something like that....dont wanna dirty this guys thread with an aguement over this..the drum is a ford pick up truck drum from 78-82..CQ..is going to run the number for me a bit later hes up to his back side in other shtuff right now..I'll be sure to make sure the right numbers and model is posted for the O.P.
  18. mazdab2600
    mazdab2600
    the center hub is 2 15/16.
    1979 f150/ranger with ford 9" but i think the dana used the same drum.
  19. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yep i think thats the one he needs..it will work for the 10X2" shoes or the 10X1-3/4" shoes
  20. ECIGUY
    ECIGUY
    Those are 74-77 Maverick drums, center hole measures 2.775 inches. That's the good news, bad news is the guys that made them for NAPA no longer make them. NAPA number is 87025, might find a warehouse that has them. Good luck.
  21. mazdab2600
    mazdab2600
    raysbestos cross.
    75 maverick to #2667
  22. captainflight
    captainflight
    A lot of guys use the Maverick rearend in 49-51 shoebox fords so there is quite a bit of info on the www.Shoeboxford.com site. Many guys, it seems, use the rear disc brakes from early 90's crown vics. Apparently it is easy and cheaper than new drums that can be up to $150. a piece if you can dind them.
  23. Von Rigg Fink
    Von Rigg Fink
    from Garage
    8923 come up as 81-82 ford f100
    im sure this is it....and it will not cost you over 38 bucks each..screw all that 100 or 150 dollar drum ****..
  24. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ok i just got off the phone with him
    8923 or 8923BDR is for a 80-82 F-100 or 80-82 F150
    $34.89 each
    these will get the job done..and with a reasonable cost
  25. BELLM
    BELLM
    I just rebuilt a Maverick 8" & put it under my '34, NAPA wanted around $90 each for drums, got them from Rockautoparts online for areound $30-35.
  26. sawbuck
    sawbuck
    from 06492 ct
    thanks all...gotta love the hamb..
  27. bluestang67
    bluestang67
    Sounds like some 67 mustang figures 2 inch on the V8 and 1 3/4 on the 6 cyl and I paid 30 a piece for the rear drums for the V8 at Major auto parts here locally
