Technical Ford 8 inch axle question
Discussion in 'The Hokey Ass Message Board' started by DougMac, Nov 26, 2019.
  1. DougMac
    DougMac
    How can I tell exactly what Axle I need? I’ve got an highboy coupe with an axle that suffered a spun bearing on the p***enger side. I was going to sleeve the axle and have another bearing pressed on, but once the machine shop put the axle on a lathe, it shows to be bent slightly. I need a new axle, but they are not easy to find. It looks like I will either have to replace it with an aftermarket axle, or order a used one off the web....... either way, I want to insure that what I buy is exactly what I need. There is no tag on the rearend...... is there a a way to identify this rearend? All I know is that it is a 8inch, 5 lug, Ford. Any advice is greatly appreciated!
    jimmy six likes this.
  2. GordonC
    GordonC
    All I know about the 8 inch is that it looks like a 9 inch too me and if it was out of a V8 car, Mustang, Falcon, and so on it has 5 lugs and the axle housings taper down as they go out towards the brake drums. I think there is one in parts for sale right now.
    DougMac likes this.
  3. 3quarter32
    3quarter32
    Axle length and number of splines should get you a good start in your search.
    DougMac likes this.
  4. mgtstumpy
    mgtstumpy
    Only 28 spline in 8", I believe they were all small bearing ends as well. Measure axle face to axle face when in housing and housing flange to flange to determine overall width and narrow [donor car] search down.
    Axles can be straightened, we had them done years ago for accident damaged cars and no issues whatsoever provided axle isn't too far gone. I had an 8.8" axle sleeved and it later walked down the axle, not recommended.
    Easier to measure you current axle and buy a generic splined axle to suit, you may have to have it cut to length to match your current axle. Generic axles comes in a various lengths and are cut to fit. Make sure the measurements match your existing axle so your brakes will fit.
    Pist-n-Broke likes this.
  5. DougMac
    DougMac
    Thank you! I’ve looked at at an aftermarket axle and honestly, that’s probably the avenue I need to take. Measurements to be sent are simple. Thanks for the advice!
    mgtstumpy likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    Stock 8 in axles should be easy to be still located . I maybe light years behind but there were 100s of millions used in the years of service . After market axles to replace and use for driving and not racing should not break your budget . How many dollars does safety cost ? Only way to fly in my manual is safe .
  7. bobss396
    bobss396
    Some yards are hesitant to bust up a complete rear, but some do stock axles on the shelf, hit or miss. I like the aftermarket idea.
  8. DougMac
    DougMac
    Apparently we both are light years behind [emoji23]. I’ve called every salvage yard in a 300 mile radius and they all laugh. I really thought this was going to be a fast and easy part to find and replace...... looks Ike I will have to order an aftermarket axle after all. Thanks
  9. loveoftiki
    loveoftiki
    from Livonia,Mi
    Check out Dutchman axles..supposed to be 30% stronger than others in the market
    DougMac likes this.
  10. tommyd
    tommyd
    from South Indy
    This is one of the times that facebook could be helpful. With all of the Mustang , Fairlane and Maverick groups someone could I.D. it and would have one laying around.
    irishsteve likes this.
  11. DougMac
    DougMac
    You would think that..... I have search on FB marketplace and placed an add on 8 different car pages...... nothing. I’ve even called mustang shops hours from my home..... nothing. Even if I find one, it will be 54 years old and possibly bent and require a new bearing installed ($100). I’m going to order one Monday from Dutchman Axles. They will make it as a complete, bolt on axle with the bearings, back plate, lugs..... $160.
    tommyd likes this.
  12. DougMac
    DougMac
    Ordering one from them Monday! Spoke to their Tech guy and this is the way to go! Thank you sir for the recommendation.
  13. oldiron 440
    oldiron 440
    I've got a pair of axles for my Fairlane so post the M measurement and I'll see what I have. If mine works you can have it for the ride.
  14. loveoftiki
    loveoftiki
    from Livonia,Mi
  15. DougMac
    DougMac
    Awesome! Need just 1, the p***enger side. It’s a 28 spine, 5 lug, drum brakes. 28.25 inches long! Hard to find.... think it’s a 65-66 mustang v8 rearend! Thanks for checking!
  16. oldiron 440
    oldiron 440
    I'll go out in the morning and see what they are.
    DougMac likes this.
  17. lake_harley
    lake_harley
    Search for axles in the cl***ifieds. I'm almost positive someone had and ad for axles.
    Lynn
  18. DougMac
    DougMac
    Thanks.... I did. They were for 68-89 mustang..... which are the wrong length. Needle in a haystack!
  19. lake_harley
    lake_harley
    Sorry that didn't work out. A source for a cut-to-fit axles that I don't think was mentioned is Yukon. I used one when I narrowed one side of a 8" Ford housing for my Model A. I forget what the price was. Measure twice, make that 3 times, and cut once. :) Simple to cut in a chop saw.
    Good luck in whatever direction you chose to go for an axle.
    Lynn
    gimpyshotrods and DougMac like this.
  20. Binkman
    Binkman
    Check with RitterDavid here on the HAMB, he has a load of 8 inch and 9 inch ford parts. He posts daily and has posted axles, housings, gears, 3rd members, parts, etc. As long as you have the dimsenions he should be able to help you.
    lake_harley and DougMac like this.
  21. loveoftiki
    loveoftiki
    from Livonia,Mi
    He’s a good seller too...helped me out with a bellhousing, it arrived in perfect shape, nice and clean...
    lake_harley likes this.
  22. lake_harley
    lake_harley
    ^^^^That's who I was thinking of when I posted earlier. I agree, he's good to deal with. I bought a 8" ring and pinion from him and was pleased with the price and the parts I received.
    Lynn
  23. 37slantback
    37slantback
    DougMac, where are you located?
  24. fiftyv8
    fiftyv8
    from CO & WA
    Probably get a whole rear end for the price of 1 new axle with change, if you can find one local and are prepared to purchase the complete unit.
    It always pays to list your location as well.
  25. DougMac
    DougMac
    Northeast Texas!
  26. DougMac
    DougMac
    I found him on the cl***ified page and contacted him. He carries 67-69 mustang rearends....... I need 65-66 V8(5lug) axle.
  27. fiftyv8
    fiftyv8
    from CO & WA
    Are these any good to you?
    eBay item number:
    132931501858
    eBay item number:
    202577419104
  28. rod1
    rod1
    This is a time I would suggest going the route you took in ordering a new aftermarket axle.I have a reminder 8" axle in the yard That is Sheared off in the thick part of the axle.It came off my buddy's 37 delivery.His girlfriend was driving back from Bonneville ,Pulling small trailer .On I-70 in Utah,Hit dip,axle sheared,wheel p***ed them at 70mph.She had the presence of mind to guide it to the side.Sparks a Flying!Wiped out the p***enger quarter ,and fender.But ,they were alive.
  29. junkyardjeff
    junkyardjeff
    You can use a small baring axle from a 9 inch if the length is the same, I have one in the maverick 8 inch thats in my sunliner.
