Technical Ford 8 or 9 inch
Discussion in 'The Hokey Ass Message Board' started by dirt t, Oct 16, 2016.
  1. dirt t
    dirt t
    Ok guys and gals the HAMB solved my Vega mounting bolt hole dimension's now I need the dimensions for Ford 8 or 9 inch pan hard mounting bracket.
    Thank you
    Terry aka dirt t
  2. dirt t
    dirt t
    Squirrel, I did a search :)
    belair likes this.
  3. squirrel
    That's good. I don't really know what you're asking for, though. Not enough information in your question
  4. dirt t
    dirt t
    Looking for the pattern for the bracket that bolts to the 3rd member so a pan hard bar can be connected.
  5. big duece
    big duece
    from kansas
    Get a gasket.
    squirrel likes this.
  6. squirrel
    the tricky part is figuring out which way the gasket fits.
    I learned long ago to not try to make parts that have to fit other parts that I don't have sitting in front of me.
  7. Larry T
    Larry T
    Is there a "standard" mount? I would think that every application of a modified part could use a little different design.
    As squirrel says - bolt it together, pull up a chair and look at it for a while.
    BTW, a 8" and 9" will be different.
  8. dirt t
    dirt t
    The pan hard bracket fits both 8 and 9 " I have not had good luck with gaskets and usually end up with hogged out holes . I would like a better product.
  9. wisdonm
    wisdonm
    I'm not aware of any factory 8" equipped cars that had a factory panhard rod. Mine has a 5/8" bolt welded to a bracket that's bolted on with the spring U bolts. A bracket that would mount to the pumpkin is too short for my liking.
  10. dirt t
    dirt t
    Wisdonm, google pan hard bracket 8 or 9 " ford. If I knew how to add a link I'd do it. This is not
    a stock ford item it's an after market bracket that bolts to the 3rd member for the pan hard bar to bolt to. that way there is no welding on the axle housing.
  11. aaggie
    aaggie
    There are no absolute rules on the bracket and where in the ch***is the rear end housing sits will make a difference. I would mock up the rear end under the ch***is where it needs to be and fabricate a bracket that welds to the housing and another that would attach the other end of the bar to the frame. The type of suspension matters a lot too. If you are using coil overs I would consider a Watts link to keep it centered.
  12. dirt t
    dirt t
    aaggie, I used watts linkage on my 23 C cab work's well. This is a 30 A ccpu.
    I built the frame from Paul's example here on the HAMB . I used the demission's of another HAMB member for the Vega box mount. I like to build my own stuff the reason for this bracket is I don't have room for watts linkage. I've seen two types of brackets one bolts to the 3rd member bolts at the top. The other bolts to the snout of the 3rd member. They are $ 30.00 + dollars . Thanks' for the input .
    Terry aka dirt t
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It is easy to chase white rabbit's or in this case, a squirrel. "Remember what the dormouse (squirrel) said
    Feed your head"
    55willys likes this.
  14. dirt t
    dirt t
    I haven't a clue what your saying or inferring . ^^^^^
    Does it have any thing to do with dimensions of the brackets I want to build?
    Johnny Gee and squirrel like this.
  15. wedjim
    wedjim
    from Kissimmee
    Dirt, I bought a kit from Speedway that worked great. I'm using an 8" in my 32 and the kit was really reasonable. If I can find the instructions in my paperwork Monday, I think the dimensions are there, I'll post it here after.
  16. brigrat
    brigrat
    from Wa.St.
    I bought a kit from Welders Series, love it, used to make my own but can't for what he sell's them for if figuring time involved ..............................
  17. brigrat
    brigrat
    from Wa.St.
    If it's set in stone your gonna do your own, take a piece of hard paper for a template and a ball peen hammer and tap the hole locations. The 4th hole can be figured any where above that's appropriate for bar location to other side. Longer the bar better the ride. I have used the carrier bolts for the brackets and also have used the front yoke plate to get it lower if need be..............................
  18. mgtstumpy
    mgtstumpy
    Do you want a pinion mounted panhard bar that sits forward or a case mounted bar that sits closer to housing. There are a few different ways to do it.
  19. dirt t
    dirt t
    msgtstumpy That's exactly what I want to build.
  20. dirt t
    dirt t
    With the age of CAD drawing I thought this would be a piece of cake.
  21. HotrodHR
    HotrodHR
    Sometimes the old fashioned draw your own template is all that's needed...
    That's what hotroding is all about!
  22. squirrel
    picture number 3 looks like it might actually work well. Notice there is support on both sides of the bar.
  23. dirt t
    dirt t
    hotrodHR That's not my strong suit. I end up with hogged out holes , I'd like to have a better product. That's my last resort.
  24. squirrel
    Practice your layout and machining skills on s**** metal, until you get good at it....
    (I get to teach the kids on our robotics team to do this type of work, I'm familiar with the challenge)
  25. dirt t
    dirt t
    Thanks squirrel, I'd have to agree with you. That's my last resort. On my Vega steering mount I tried three times then did it on the first try with the dimensions.
  26. squirrel
    so, you have a problem measuring the part....hmmm....
  27. dirt t
    dirt t
    Just the holes. I'm laughing.
  28. Flathead Dave
    Flathead Dave
    from So. Cal.
    I have the pinion mount. No muss, no fuss.
  29. Flathead Dave
    Flathead Dave
    from So. Cal.
    Like Sgt. Friday would tell the lady..."Just the holes, Maam."
  30. dirt t
    dirt t
    FD are you using the pinion mount? I am leaning towards that as it sits forward of the axle housing and looks to not congest the area.
