My crank was ground .020" on the rods and mains. The block has been bored to .080" over standard. I'm using original rods and pins. The machinist thinks I'll be OK but he's still going to call a few people and see for certain. He's gone to .060" over standard with these and put them together with no problems but he hasn't built tons of them. This engine will have a super easy life. It'll be a lucky thing if I can even get a Model A rolling ch***is to mount it on. It'll probably just run on a stand. I'm in it for $1800 so far which I guess is pretty cheap for these things. If it's going to destroy my engine I'll get it done. I'd seriously eat a bullet if I killed this engine. No idea what it could run to get a crank balanced but if it needs doing, it'll get done.
I called around and found a shop for $225 if they don't run into ********. Cheap insurance. I'll do it.
Sometimes you can be lucky and find the reground crank and oversize pistons just work well together. Sometimes not. It is a lot of work to strip an engine for balancing after ***embly. I have always spent the money to have the whole ***embly balanced. Nice when someone notices and comments about how sweet it runs.
