Technical Ford 9” Big Bearing Old Style Axle Flange Gasket Part Number?
Discussion in 'The Hokey Ass Message Board' started by ZakBradshaw, Jan 21, 2018.
  1. ZakBradshaw
    ZakBradshaw
    I have looked all over and cannot find the correct axle housing flange gasket for my Ford 9” big bearing old style flange. It’s the one that is shaped like a “D”. Does anyone know the correct gasket part number?
    Thank you,
    Zak.
  2. They are not really necessary, if you want to use something wipe a bit of silicone on it and bolt up the backing plate.
    Center of the Galaxie likes this.
  3. lostone
    lostone
    from kansas
    ^^^^^ black silicone and forget it
  4. ZakBradshaw
    ZakBradshaw
    Okay, I’ll just use some RTV on it. Thanks guys.
  5. deathrowdave
    deathrowdave
    from NKy
    I don’t know I have ever seen a replacement gasket and I worked at Ford dealer in parts Dept
  6. dalesnyder
    dalesnyder
    You can cut odd ball gaskets out of breakfast serial boxes.
  7. 8 inch small bearing is Felpro 55035...i think you need 55036?
    as said , you really don't need them
    KCTA Chris likes this.
  8. gdaddy
    gdaddy
    from nw fl.
    don't do like my buddy did one time , cut a gasket out of a nice hand held fan , near perfect , made in 1934 date on it , made me sick .
  9. Cali4niaCruiser
    Cali4niaCruiser
    I've been looking all over the place for these, but cant find a source. I'm sure gasket maker would be fine, but I'll probably end up making a set.
  10. nochop
    nochop
    from norcal
    No gasket required. https://www.currieenterprises.com/axle-seals
  11. nochop
    nochop
    from norcal
