Hot Rods Ford 9” marking identification
Discussion in 'The Hokey Ass Message Board' started by meshach, Dec 27, 2017.
  1. meshach
    meshach
    from Fresno, CA
    6E5AAF0B-B6F4-4011-B23E-C36349F0B412.jpeg 64264AB3-AF45-4E01-A8A9-C623C5A5AC80.jpeg C6D10B33-370A-43D2-A48D-3B24856A8515.jpeg DD4AA291-6A61-4B3C-814E-7B772A7D2976.jpeg A7FE6E91-8D2D-48D4-9C27-FC02D01FF5C7.jpeg these are marking on the dif of a ford 9” I’m planing to use and I need help identifying them, these pictures were sent to me so this all I have at the moment. Trying to figure out the gear ratio if that’s possible All help appreciated. I see, dif 17, 4210, 4025,
  2. squirrel
    Not much to go on....they often had the gear tooth counts stamped on the ring gear, but not in that picture (although it looks like we can see the beginning of it, "4", at the bottom of the picture). The ring gear is really thin, so it's probably a 2.75 ratio or close to it. The housing casting engineering number of C1... indicates it's probably a 1961-66 center housing, since C7.. was pretty common, and it came out it 1967. Yet the gears are D2... which is 1972 or later.
    The loose pinion nut means it needs some work...I'd put a new crush sleeve and some seals in it at the least, and inspect the bearings to see what else it needs.
    meshach likes this.
  3. meshach
    meshach
    from Fresno, CA
    It’s a shop being rebuilt I purchased the case and third member for 150 and a shop is doing the rebuild but I haven’t had time to ask the gear ratio. 2.75 might be too high for application as I’m running a C-6 and 427 stroker in front of it.
  4. squirrel
    You might want to ask them, before they get too far along with it :)
    I just made a wild guess on the gear ratio. But a 4.11 ring gear is much thicker...here's a 4.11 on the left, 2.75 on the right.
    The ring gear thickness is related to the gear ratio, because of the number of teeth on the pinion gear. Fewer pinion teeth (and smaller diameter pinion gear) on the steep ratio gears, more (and larger diameter pinion gear) on the highway gears.
    But yeah, call them up and talk about ratios.
    Beanscoot and meshach like this.
  5. squirrel
    looking at some other gears...you might have a 3.50 ratio there.
    meshach likes this.
  6. gimpyshotrods
    gimpyshotrods
    My fuzzy memory says 3.25:1. Just count the ring gear and pinion teeth. Divide one by the other, and Bob's your uncle.
    tommyd likes this.
  7. Hoptup32
    Hoptup32
    If its an earlier case as Squirrel has alluded, then it may have a 28-spline carrier vs. the stronger 31-spline unit. If you already have axles and a rear end axle housing, I would confirm the spline count on this unit is going to be compatible before investing more $$ on rebuilding it.
  8. meshach
    meshach
    from Fresno, CA
    Okay 3.50 would be an ideal ratio and would work perfect for me. I was initially told by the person I purchased it from they believed it to be 3.30 - 3.50.
  9. saltflats
    saltflats
    from Missouri
    If you have it at a shop being rebuilt why don't you contact them and ask what ratio it is and if it's not what you want them have them set it up with your choice?
    RonaldR likes this.
  10. meshach
    meshach
    from Fresno, CA
    It was just dropped off and I they haven’t had a chance to go through completely yet so I was just hoping for some answers before hand. Sorry
  11. Beanscoot
    Beanscoot
    DIF = Dearborn Iron Foundry.
    meshach likes this.
  12. meshach
    meshach
    from Fresno, CA
    Oh that’s cool to know,
  13. meshach
    meshach
    from Fresno, CA
    What would be a recommended gear ratio I was planning on 3.30-3.50 for primarily street use and freeway. I’m running a C-6 with a TCI Super street fighter torque converter.
  14. bobss396
    bobss396
  15. Mr48chev
    You don't believe on ring an pinion gear ratios when you have them in front of you. you count the teeth or read the stamped numbers and know exactly what you have. I have my wonderments about the outfit you are dealing with.
  16. saltflats
    saltflats
    from Missouri
    We would need more information to help you pick a gear for your car.
    Tell us what you have.
  17. meshach
    meshach
    from Fresno, CA
    It’s a 53 Ford customline with a 427 stroker, c6, TCI super street fighter torque converter, and this 9”. That’s about as far as I’ve gotten I don’t tire size at the moment.
  18. meshach
    meshach
    from Fresno, CA
    I am finding out that the ratio is 3.0 what day you on this?
  19. seb fontana
    seb fontana
    from ct
    With a 427 Stroker what more would you need if just cruising around..But I don't know how the torque converter you have is supposed to behave..
    meshach likes this.
  20. I am not real familiar with Ford stroker motors. What you need to know to decide on gear ratio s the operating range of the motor plus tire diameter.
    For a trade off on most moderately built streeters a 3.26 to a 3.55:1 gear works real well in my experience. But that is just my experience and not a pure science.
    Just noticed that your gear is a 3.0? I ran a 3.08 ( about the same gear) behind a motor that has its sweet spot in the 3,000 to 3,200 range. With a 28" tire that put me about 80 or so cruising on the highway. If that is any help at all.
    meshach likes this.
  21. meshach
    meshach
    from Fresno, CA
    The motor was built with primarily street in mind for this car specifically so it’s a mid range setup and so forth, the stall is suppose to be around 3k depending on setup and I’m planning on 27”-28” tires.
  22. meshach
    meshach
    from Fresno, CA
    Cam #s
    J. DIAM: STD INT EXH
    VALVE ADJUSTMENT HYD HYD
    GROSS VALVE LIFT .620 .604
    DURATION @ .006
    TAPPET LIFT 283 293
    VALVE TIMING OPEN CLOSE
    @ .050 INT 9 41
    EXH 53 5
    SPECS FOR CAM INST. @ 106.0 CENTERLINE
    INT EXH
    DURATION @ .050 230.00 238.00
    LOBE LIFT .388 .378
    LOBE SEPARATION 110.0 FIRING ORDER STD
    ROCKER ARM RATIO 1.60 1.60
  23. Beanscoot
    Beanscoot
    Increasing the stroke of an engine reduces the rpm range, all other things being equal.
  24. meshach
    meshach
    from Fresno, CA
    Is 2500rpm at 70 sound reasonable?
