Technical Ford 9" Axle Seal Replacment
Discussion in 'Traditional Hot Rods' started by Auslander, Mar 7, 2016.
  1. Auslander
    Auslander
    from Austin, TX
    So rear end starts leaking on the drivers side rear. So I pull the half shafts, remove the old seals, drift in new seals, clean everything up, repack bearings, and button it all back up. Anything else I should/should have done? Differential was full to the level of the axle tubes and bearings seem solid. Any need to drain and refill the differential? Thanks! IMG_1913.JPG IMG_1914.JPG IMG_1915.JPG
  2. Drain and refill is worth the effort IF you have 50,000 miles on the axle since the last change/rebuild. Otherwise, how often have you changed your daily?
    Then be sure to apply gasket seal to both sides of the backing plate to keep the oil in.
    Auslander likes this.
  3. oj
    oj
    Check the axle tube vent, if its' plugged that could cause the original leak.
  4. Marty Strode
    Marty Strode
    Make sure the vent is not plugged or restricted.
    PS, I see my pal OJ beat me by a minute !
    oj and Auslander like this.
  5. seb fontana
    seb fontana
    from ct
    Repacked the bearing? How?
  6. Make sure you put grease on the axle where the seal rides so that when you first start out it does not run on a dry axle!!
  7. 302GMC
    302GMC
    from Idaho
    No emergency brake ? Pull the extra parts hooked to the trailing shoe ...
    and I'm wondering how you repack a sealed rear wheel bearing ..
  8. aaggie
    aaggie
    Interested to know what you are using for a parking brake. Texas inspection requires it.
  9. LOL he has a door in the floor and he puts his feet down. :D
  10. How is the axle bearing? I'll call it the leading cause of a seal gone bad.
  11. Jibs
    Jibs
    X3, how did you pack the bearing?
  12. Fast Bill
    Fast Bill
    Surprised no one noticed that the backing plate is on the wrong side. The one in the pic is for the left side and it's on the right side. Short shoe goes in front, parking brake lever should be to the rear.
  13. Fast Bill
    Fast Bill
    Oops, I guess he did both sides. Disregard
