Technical ford 9 daytona pinion setup
Discussion in 'The Hokey Ass Message Board' started by Hoonigan, Dec 8, 2016.
  1. Hoonigan
    Hoonigan
    so im trying to setup the daytona pinon ive got with a solid spacer/shim kit. with the "standard" spacer and shims its no where close to being tall enough to stop the bearing races.
    the spacer kit im using looks like this and im not sure how the larger spacer is supposed to be used. its inner diameter fits the pinion shaft, and the outer raised lip fits around the "standard spacer" and shim outer diameter.
  2. squirrel
    this order: standard spacer, a shim, large spacer with the large side towards the shim. See how that works.
  3. gimpyshotrods
    gimpyshotrods
    Keep stacking in there until you reach proper preload.
  4. manyolcars
    manyolcars
    Just because one showcar did it does not make it traditional ;)
  5. gimpyshotrods
    gimpyshotrods
    I can provide about 50 examples, but I have been asked not to push this.
    prewarcars4me likes this.
  6. Hoonigan
    Hoonigan
    so the "standard spacer" against the inner bearing? and then the larger recessed groove side capturing the shims in between the standard spacer wile the tapered edge is up against the inner race of the outer bearing?
    squirrel likes this.
  7. Hoonigan
    Hoonigan
    that single "standard spacer" and all the shims isnt enough to set a proper preload between the inner and outer bearings
  8. gimpyshotrods
    gimpyshotrods
    Even when you stack it all up, it is still not enough?
    That's weird.
  9. Hoonigan
    Hoonigan
    yeah the aluminum daytona support has alot of material between the two outer bearing races (not a bad thing), im just not sure how that tapered centric spacer works in the stack
  10. gimpyshotrods
    gimpyshotrods
    This is a comparison between the standard and Daytona setups. The pinion shown if for the Daytona, and has a full solid spacer on it. Fine shims would be used against that to get it spot-on:
    The "big" side of that shim on the left in your picture must be placed so that the "snout" is toward one of the bearings. If you flipped it over, it might hit the cage.
  11. langy
    langy
    There are 2 solid spacer kits, one for the standard pinion and one for the Daytona, the spacer in the Daytona kit is thicker, do you have the right one ?
  12. Hoonigan
    Hoonigan
    the richmond gear kit i bought was for daytona, had the right bearings and everything
  13. Hoonigan
    Hoonigan
    my spacer isnt nearly that thick, but im trying to figure out what the other spacer/collar is for.
  14. oj
    oj
    I've had problems with the Richmond shim kits lately, Richmond sold to Motive and that might be a problem. If you can't find the right shim stuff try going to Strange Engineering, they might be the ones that made the daytona pinion support to begin with.
  15. langy
    langy
    I use the speedway solid spacer kits, the Daytona kit is 0.48 thick and the normal kit is 0.43
  16. Model A John
    Model A John
    from wichita ks
    It's much simpler to use a crush sleeve. That's what I use in my 9-second Chevy II.
  17. dave lewis
    dave lewis
    from Nampa ID
    I use a crush sleeve to do setup..
    Take it apart and measure the crushed sleeve..and then stack the solid spacer and shims to size..
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
