Ford 9" ID - help
Discussion in 'The Hokey Ass Message Board' started by vendettaautofab, Jul 5, 2007.
  1. vendettaautofab
    vendettaautofab
    I need help identifying a 9" I picked up...anyone know an online source? I did a search and yeilded nothing...I swear that thing doesnt work, ha
  2. old beet
    old beet
    Try 9inchford.com.............OLDBEET
  3. vendettaautofab
    vendettaautofab
    Old Beet, it aint working
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    Any part numbers?
  5. old beet
    old beet
    Don't work for me either. Got some pics and #s?...........OLDBEET
  6. vendettaautofab
    vendettaautofab
    Yea the tag reads
    WDX L OB19
    2 47 9 S560
    I know is a 2.47:1 ratio, just was curious what it was out of, I thought it was a bronco, but the with that ratio I dont know. By glance I thought it was the 4.5 bolt pattern, but I could have been mistaken.
  7. Hedders
    Hedders
    Do a google search for- Kevinstang's Ford Nine Inch Differential page. It is pretty informative.
    Just Gary likes this.
  8. squirrel
    if it has 5-1/2" bolt pattern axles it's a half ton, 5" it's a big car, 4-1/2" it's a midsize car
    quick google for "wdx-l" does not turn up anything
  9. vendettaautofab
    vendettaautofab
    I cant find these numbers anywhere.... Its a 28 spline, 2.47:1 gear, 58" drum to drum outside....
  10. Wyle E Coyote
    Wyle E Coyote
  11. Its from a 1980 Ford Granada or Mercury Monarch.
  12. vendettaautofab
    vendettaautofab
    Where did you find that? I guess I didnt know those had 9 inch's, thought they were all 8"
  13. Deuce Roadster
    Deuce Roadster
  14. Shifty Shifterton
    Shifty Shifterton
    V8 cars had the 9", or so I've always heard.
  15. Hollander interchange manual.
    Alot of the Granadas and Monarchs with a 351 W had a 9 inch, sonetimes a disc one.
  16. vendettaautofab
    vendettaautofab
    Ahh, alright... well 72 was casted in the center section housing, and I swear it was a WDX, but I shall check...
    We are getting closer, THANKS GUYS
  17. squirrel
    that's what the date code
    OB19
    says, Feb 19 1980 (or 1970?)
  18. SlowandLow63
    SlowandLow63
    from Central NJ
    That sounds exactly right 58" is dead on for a granada. A ford part number would tell the tale perfectly.
  19. Jeff Brandt
    Jeff Brandt
    So, I'm trying to identify the year as well as other info from this 9" that I purchased. Went to fordifacation but couldn't find these numbers.
    The gear ratio is 3.00 but other than that I'm in the dark. Any help, I would be appreciative. Thanks 17606340791838482319308688070310.jpg
  20. theHIGHLANDER
    theHIGHLANDER
    Squirrel nailed the date, these will clarify. From the 47th edition Hollander which covers 75 thru 85.
    Will that be all today?;)
  21. squirrel
    C2SA is 1962 Thunderbird...
    (ford part number breakdown: C is 1960s, 2 is specific year, S is the Thunderbird line)
    looks like @theHIGHLANDER didn't catch that the thread is 18 years old! and we have a new question to answer
  22. theHIGHLANDER
    theHIGHLANDER
    You're right, zombie victim here:eek:
    Just Gary, seb fontana and swade41 like this.
  23. Jeff Brandt
    Jeff Brandt
    Thanks for that help, much appreciated.
