Ford 9 in. axle
Discussion in 'The Hokey Ass Message Board' started by Lakehouse51, Feb 1, 2013.
  1. Lakehouse51
    Lakehouse51
    from Virginia
    Anybody got a good part number for a rear axle bearing for 1957 ford 9 in. all Larry Curly & Moe auto parts has is a computer, they don't have books?
  2. black 62
    black 62
    from arkansas
    does your old bearing have a number
  3. swade41
    swade41
    from Buffalo,NY
  4. hotroddon
    hotroddon
    9"
    Ball Bearing 9103 1.378 x 2.834 RW-207CCRA
    Ball Bearing 9104 1.531 x 3.150 88128RA
    Ball Bearing 9105 1.531 x 3.150 88128RB-R
  5. hotroddon
    hotroddon
  6. Relic Stew
    Relic Stew
    from Wisconsin
  7. Lakehouse51
    Lakehouse51
    from Virginia
    Aint that dumb ! Napa shows a 2-peice bearing that will not work, plus I need the seal also. Ford part nubers B7az-1225b and B7a-177-a just need these crossed to a current part no.
  8. Marty Strode
    Marty Strode
    Is it a large bearing 3.150" od (1/2") bolts on the backing plate, or small bearing 2.834" od with 3/8" backing plate bolts?
    Small bearing GRW 207CCRA
    Seal OS13738
    Large bearing G88128R
    Seal OS 15141
    These numbers are from a SKF catalog.
    Hotroddon had you on the right path, you need to determine the bearing size, and go from there, good luck.
  9. swade41
    swade41
    from Buffalo,NY
    At least the second page had the seal.....doh !
