Hot Rods Ford 9 inch Aluminum Chuck assembly suggestions for the street
Discussion in 'The Hokey Ass Message Board' started by ronnieroadster, Oct 27, 2024.
  1. ronnieroadster
    ronnieroadster
    For the new Deuce Hot Rod project I'm going to use a Ford 9 inch rear. My plan is to replace the Ford original chuck with an aluminum version. What I want is a 3:50 ratio with possie prefer 31 spline and a steel yoke for the U joint ready to run. Wondering what others are using.
    Ronnieroadster
    gimpyshotrods and TA DAD like this.
  2. DDDenny
  3. Budget36
    Budget36
  4. seb fontana
    seb fontana
    from ct
    How much power in front and are you going to race? The aluminum 9" if you can afford the $$ otherwise a standard or "N" iron housing will be fine. Not sure heat and tolerance change is an issue [I doubt it] in long term use with alum.. Big pinion retainer. 31 spline big brg axles [not stock shortened] made to length by Strange, Summers or of name brand will be enough. Traction lock will work well, Eaton Tru track better. I have new housing pieces for u-fab and big brakes if interested and arbor for loan for alining. SSC front disc for earl Ford spindles, f/c bolt pattern.
    gimpyshotrods likes this.
  5. seb fontana
    seb fontana
    from ct
    Think so.
  6. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    Moser made all my stuff. Aluminum center with 4.56's shown. Never any problems.
    Bill's Auto Works and TA DAD like this.
  7. What's the weight difference between fully assembled iron and aluminum differentials?
  8. seb fontana
    seb fontana
    from ct
    Weight difference, not much. I would guess around ten lbs, more or less, as you add material in strategic places to increase strength, add thru bolts bigger bolts etc..
  9. DDDenny
    I lost ten pounds on the third member but got it back on the housing.
    Bill's Auto Works and Just Gary like this.
  10. saltflats
    saltflats
    from Missouri
  11. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    Any little bit helps when you're doing the ''jackpot bench press"!
  12. BadgeZ28
    BadgeZ28
    from Oregon
    A number of the Ford pickups had a 3:50 31 spline posi 9" .
  13. 19Eddy30
    19Eddy30
    from VA
    Maybe to Extreme !!
    But seriously, if you do not have axles or 3rd , A 9 with 28 spline under
    3,000 would be fine,
    Another option , I was running a s10 from salvage yard with possie Gm parts with a 408 & 427 cid with torque over 600 on 3:43 gear 29 tall tire , with enough wheel speed to run @ & over 100 in 1/8th close to 10 years no breakage,
    Before switching to a 9 to plant tires @ launch
  14. 42merc, saltflats and Just Gary like this.
