Ford 9 inch axles
Discussion in 'The Hokey Ass Message Board' started by d.reese, Dec 6, 2011.
  1. d.reese
    d.reese
    Forget that there are big bearing / small bearing, the length, 28 / 31 spline and the bolt patteren for a moment and answer this:
    Are all Ford 9 inch axles the same size where the bearings press on?
  2. ryno
    ryno
    Diameter of axle is what your asking?
    Id of bearing?
  3. CutawayAl
    CutawayAl
    from MI
    The bearings don't press into the axle so I ***ume you are talking about axle shafts.
    All axle shafts don't accept the same ID of bearing.
    P.S. Axle is spelled AXLE, not axel.
  4. Brickster
    Brickster
  5. Weedburner 40
    Weedburner 40
    The diameter at the point where the bearing fits is larger on the 31 spline axle shaft than on the 28 spline. The entire axle shaft is larger diameter on the 31 spline.
  6. d.reese
    d.reese
    Axle is spelled AXLE ~~~CHECK!
    Thank you!!
  7. Willy301
    Willy301
    I think he was talking to your ***le, not your post D. but no, they are different diameters as stated above...
  8. Relic Stew
    Relic Stew
    from Wisconsin
    Since we're on the subject of 9" bearings... Something that isn't discussed much is that the center section also comes in 2 different bearing sizes, 3.062" OD 1.781 ID and 2.891 OD 1.625 ID. The 31 spline needs the bigger carrier, the 28 spline can have either.
  9. CutawayAl
    CutawayAl
    from MI
    It's a common mistake. The word isn't spelled like it sounds.
