Projects Ford 9 inch questions
Discussion in 'The Hokey Ass Message Board' started by Th0tSlayer117, Mar 21, 2021.
  1. Th0tSlayer117
    Th0tSlayer117
    Hello, I'm new to posting here, but I've read several threads on the hamb before.
    I'm wanting to upgrade some pieces on my 9 inch, but I don't have the funds right now to completely upgrade the whole thing at once. I'm pretty sure I want a nodular iron 3rd member, and correct me if I'm wrong, but I might have read that there are some 10" ring gear 3rd members out there and how a 10 inch ring gear will be stronger than the standard 9 inch. However, I've also read that a 10 inch ring gear won't last long on the street, which is where my rig will mostly be driven. Another deciding factor as to which I should get a 10 inch ring gear or not is if a 10 inch will fit into a factory housing. Also I believe I've read that not all 10 inchers aren't actually 10 inches, more like 9.5 inches. I should say that I don't know if I'll buy another ring gear yet, I just wanted to know what housing I should get. And I'm realizing that a 10 inch 3rd member might not let the pinion and standard 9 inch ring mesh correctly, so if I wanted to do it, I'd have to do both.
    Secondly, I am lead to believe that there are two different pinions for the 9 inch that were from the factory, 28 and 31 toothed pinions. I'm not sure which pinion I have. (The axle is under a 1978 F-150 4x4 if that helps identifying anything.) I don't know what the swapability options are with the pinions and their tooth count. And I don't know if there are bigger pinions offered aftermarket.
    Thirdly, is the Daytona pinion support the strongest pinion support out there? I'd like to get one of those if I get a third member, but will it just bolt on the the 3rd or will I need bigger bearings to go along with it? And does it matter if I get an aftermarket one or a factory one? How easy/difficult is it to install or swap a pinion support?
    Fourthly, does anyone make a bolt on truss for a Ford 9 inch?
    Ultimately, by the end of it all, I'd like a full floater with 35 spline axles, either a Detroit locker or Yukon Grizzly, (feel free to chime in and tell me which one I should get) mabye a 10 inch ring gear, and a Daytona pinion support. I'm not fond of the idea of cutting and welding my axle housing to convert to a full floater. I've seen a company called Miller Built who makes bolt on floater kits. Does anyone besides them make those things?
    I'm just wanting to get a sense of what I can do with the axle as of now to beef it up. Any input is apprectaited
  2. Budget36
    Budget36
    The larger ring gear won’t work in a 9 inch housing as-is, but looks like you may be want a 4x4 forum instead?
    stillrunners and squirrel like this.
  3. Th0tSlayer117
    Th0tSlayer117
    Yes, I believe your right. Thanks.
  4. Mr48chev
    There are some of those slightly larger ring gear but look almost the same rears around but I don't think the pieces interchange.
    I haven't seen the 35 spline axle thing but that may be a race car only deal for the big $$ boys.
    It sounds like you need to be on a race car only board rather than a traditional hot rod and custom car board though. Hotrodders dot com has a section that is just about nine inch rears . Search results for query: 9 inch rear axle | Hot Rod Forum (hotrodders.com)
  5. Th0tSlayer117
    Th0tSlayer117
    Thanks a bunch
  6. DDDenny
    As far as I know most everyone calls the larger ring gear/third member out as a 9&3/8".
    Those are generally real high geared (low numerically), I think in the 2.73, 3.00 range.
    Another important thing to know is the aftermarket does not support them much with parts such as ring and pinions, posi's, etc.
    Yes, the larger ring gear will fit the standard 9 inch housing with some clearance grinding.
    Sounds like besides being limited in funds you may also be looking at this with a "bolt-on" point of view and I think one of two things needs to happen and that is either get a medium sized MIG welder and teach yourself how to weld or get real friendly with someone who does, many times "bolt-ons" are a compromise and end up being replaced later anyway.
    Desoto291Hemi likes this.
  7. southcross2631
    southcross2631
    Sounds like you need to stop reading so many magazines and internet articles.
    If you are working on a late model 4x4 you need to go to different site.
    Speedway sells a reasonably priced chunk for a 9 inch already to bolt in your choice 28 or 31 spline. Posi or spool. Nodular case Daytona support. Great for the street or moderate compe***ion.
    Sent from my SM-A505U using The H.A.M.B. mobile app
    stillrunners likes this.
  8. hemihotrod66
    hemihotrod66
    The best place I have found for 9 inch Ford hotrod parts is Mark Williams Enterprises...Pricey but well made...
  9. big bird
    big bird
    9-and-change is a (really) obsolete unit, even by HAMB standards. Parts are hard to find. More power loss than an actual 9". The complete center chunk will fit a standard 9" housing with a little grinding, if you really want to. But, why?
  10. MeanGene427
    MeanGene427
    from Napa
    The 9-3/8 was a big- boat deal, Birds, Lincolns etc. You can swap things around if you must, but the 9-3/8 is a red-headed stepchild. I have had folks tell me that the 31-spline housing and axles from a 66 428 Bird in my 406 car is a 9-3/8 unit and incompatible, but it has a 9" N case with a spool and 5.14s in it, been that way since around '78
  11. TRENDZ
    TRENDZ
    You can’t be limited by budget, and do what you want to do. Save your money and buy all the parts at one time.
    If you really need a bigger ring gear than a 9”, you need to step up. No stock nodular case, no Daytona pinion support. You go to Strange, order an ultra case with a 12 bolt pinion support, bigger bearings, spool deflection load support, billet caps with through bolts, designed for 9”, 9 1/2”, or 10” ring gear.
    If you want a diff, and 35 spline axles, then you don’t need a bigger ring gear. The standard 9” ring gear will be plenty strong for the axles and any diff you put in it.
  12. oldiron 440
    oldiron 440
    Full floater 9"? Sounds like a Dana 60 or a corporate rear axle ***embly to me.
    How do these people get here?
  13. MeanGene427
    MeanGene427
    from Napa
    There have been full-floater 9" setups in NASCAR for many, many years
  14. oldiron 440
    oldiron 440
    Not in factory ford PUs, the Dana and corporate floater axles had 10" ring gears, I think he's got thing a little confused.
    Boneyard51 likes this.
  15. Boneyard51
    Boneyard51
    Let’s get more confusing, Ford pick ups also came out with semi floating Dana sixties! Lol
    Bones
  16. deathrowdave
    deathrowdave
    from NKy
    Don’t try to redesign the wheel , as has been discussed . N case Daytona Support and 31 spline with a Detroit Locker and it will be tuff for you to bust it . It you brake that , a 9 3/8 ring gear in not the answer . I think some cl***es on being an Adult should be next in order first .
  17. oldiron 440
    oldiron 440
  18. deathrowdave
    deathrowdave
    from NKy
    Bones , I just saw your post Ford and Dodge , came OEM with semi float Dana 60s . When we say rare , and strong , this is the definition but they are there .
  19. Boneyard51
    Boneyard51
    Not sure about the semi floating 70s but I have a semi floating 60, 3.54 gear with a power loc. Scored it years ago out of an about 1967 Ford 1/2 ton pick up. I think it is very similar to the rear ends in some of the Hemi power cars.
    Bones
  20. MeanGene427
    MeanGene427
    from Napa
    Yep, there were some 1/2 ton Ford pickups with Dana 60, seen a few in 4x4s. Somebody got the idea that the 9-3/8 was somehow superior to the 9, but in performance setups, no- it was a barge unit
  21. Marty Vanin
    Marty Vanin
    This is is really OT,but this is what I know.
    Pinion spline is 28 stock or 35 spline on the pro gears.
    Gear sets come in 9, 9 1/2, or 10 inch.An aftermarket carrier and pinion support will be needed for the larger gears and 35 spline axles.A floater housing was used in NASCAR and drag cars.To the OP, this setup you want is not cheap and if you are going to do it ,I suggest you contact MW or Strange and get a complete ***embly
  22. Marty Strode
    Marty Strode
    Your F-150 housing has the pinion offset to the p*** side 4-3/8", so if you bolt on floater ***emblies, the rear will be extremely wide and the pinion offset will still be a factor.
  23. jaracer
    jaracer
    What are you building and what do you want to do with it? For a street rig, a stock 9 inch is a pretty strong rear axle ***embly.
  24. stillrunners
    stillrunners
    from dallas
    Seen them even in a Chevy 1/2 ton 1969 with a 396 4sp....Dana 60 that is....factory tach truck and a buddies...
