Ford 9" rear end in a 54 IHC R100
Discussion in 'The Hokey Ass Message Board' started by Phartung, Mar 23, 2011.
  1. Phartung
    Phartung
    from Yelm, WA
    Anyone know or have any idea if a ford 9" will fit in the above mentioned truck? Will it require any fab and what?
    Thanks,
    Pat
    Party 'till impact
  2. This thread was posted today.
    http://www.jalopyjournal.com/forum/showthread.php?t=573291
    Scroll down and you can find dimensions for the various 9" Fords.
    You will probably have to move some spring perches to meet up with your springs and get a bastadr joint to hook up the frive shaft. may even need to shorten the drive shaft if the yolf sticks out farther on the 9" then the IH.
    The IH doesn't have an enclosed drive shaft does it? If the Binder has an enclose drive shaft you will need to get an open drive transmission for it.
  3. willowbilly3
    willowbilly3
    from Sturgis
    I have a 3.55 8.8 from a Ford Exploder that is for my 54 R100 project, seems to be about the right width. Pretty easy to find one with a limited slip, 100-150 bucks around here.
  4. 55_International
    55_International
    from SLC, Utah
    Try over at www.oldihc.org
    There is a guy NW that has done the Ford 8.8 with pics, descriptions, numbers, etc.
    Aaron
