ford 9" smaller drums
Discussion in 'The Hokey Ass Message Board' started by dondogarage, Dec 6, 2012.
  1. dondogarage
    dondogarage
    from richmond
    need smaller drums want to use 35 ford wires .bronco 9" 5/5.5 11 drums are to big for my wires
  2. Smaller drum will mean smaller everything..... Drum, shoes, hardware, backing plate, etc.
  3. dondogarage
    dondogarage
    from richmond
    i know but are they available
  4. MeanGene427
    MeanGene427
    from Napa
    Does your housing have the small bearings like a Mustang? IIRC, backing plates & drums from an 8" will bolt on a small-bearing 9"- and there were some pretty small 6-cylinder 8" brakes. Hope your car is pretty light
  5. Dirty Dug
    Dirty Dug
    Even with smaller drums you'll still need one inch spacers.
  6. percifab
    percifab
    from Dixon,CA
    You will need 1 1/4 spacers
  7. dondogarage
    dondogarage
    from richmond
    I think if I had smaller drums they would fit the wheels,without a spacer
  8. dondogarage
    dondogarage
    from richmond
    I think you are correct if i had 1.25 spacer my 9" would work where would i get them. Thanks
  9. Dirty Dug
    Dirty Dug
    Yeah, if they were about 8"s in diameter. Even with 10" drums spacers are necessary.
  10. Dirty Dug
    Dirty Dug
    Contact Wheel kid here on the Hamb.
  11. 6-71
    6-71
    My bronco 9" had 10" drums. I changed it over to the 11"backing plates and drums.The 10" drums are very pricey if you can locate them.If you use anything other than the bronco drums you will have to redrill the bolt pattern which is no big deal,just more work..
  12. Mr48chev
    First generation Broncos could be had with either 10 inch or 11 inch brakes if that helps
    Here is the O'Reilly cheat sheet for the 68 Bronco drums
    http://www.oreillyauto.com/site/c/s...p?year=1968&make=Ford&model=Bronco&vi=1105287
    The others answered while I was digging and confirmed that thought in the back of my head that it will still take a spacer to make the wires work with the later drums. I'm running into that with my Model A and the nine inch and 35 wires and will have to have the axles cut that much more to compensate.
  13. dondogarage
    dondogarage
    from richmond
    ordered 1.25 spacers to day thanks
