Technical Ford 9" trac loc carrier?
Discussion in 'The Hokey Ass Message Board' started by Smitty's32, Dec 5, 2022.
  1. Smitty's32
    Smitty's32
    Always thought this car had an open rear end until it came apart. Looks like a trac loc. Anybody spot the problem in the pictures? How did something like this come to be?
    Deuces and wood remover like this.
  2. Looks to me like one axle drive. :) Did it make noise when turning?
    wood remover likes this.
  3. Marty Vanin
    Marty Vanin
    Didn’t they have a block with 4 springs and 4 guide plates for the clutches?
  4. jaracer
    jaracer
    I don't see a problem, were you having one? When you put one of these together, there is a special tool to set the clutch pack clearance. I borrowed one when I did my trac-loc. Somewhere I made a scaled drawing and put it away for future reference. It must be safe because I can't find it.
    I don't know what manual I found the special tool in. I just checked a few manuals and the only check they have is after ***embly. You hold one side gear or axle stationary and check the torque to turn the other side gear or axle. With new clutches properly soaked in trac-loc fluid, new clutches should take around 175 ft lb to continuously turn them. With old clutches it drops to a minimum of 75 ft lb.
  5. seb fontana
    seb fontana
    from ct
    Yes they did. Maybe that is a Moser or Currie or China copy. When I rebuilt mine I think the clutch pack rebuild kit came with the set tool? Just had a thought; if there are five drive scallops it is a equa-lock predecessor to the Traction-lok which has 4 drive tangs.
  6. Smitty's32
    Smitty's32
    It made no noises, just worked like an open rear end. The problem is there are no springs. Clutches look like new since they have never been used. Should be a square block between the spider gears with 4 springs and a plate. This appears to be an open rear carrier half that someone has mated to a trac loc big end half. Is that possible? Can I add the square block and springs to this one or was the other half of the open carrier different than the trac loc?
  7. indyjps
    indyjps
    Yep, I rebuilt my first one, put new clutches and steels in, put it back together. Didn't work, Took it out, checked everything, put it back in. Didn't work, Took it out.
    Carried the center section into performance transmission place and asked what was wrong. He told me nothing - except I don't know what I'm doing. :D I paid for him to re***emble it as long as I could watch.
  8. greybeard360
    greybeard360
    I think what you have is an Equa-lock differential not a Trac-lock. It used a bellville spring/washer to apply pressure to the clutches.
    Wanderlust and seb fontana like this.
  9. seb fontana
    seb fontana
    from ct
    The block in the center isn't the main spring, looks like you are missing the Bellevue spring plus there are 5 drive scallops so it is not a traction loc. If there are five drive scallops it is a equa-lock which is a Ford and predecessor to the Traction-lok which has 4 drive tangs. Rare 4 pinion, most were 2.
    Wanderlust and greybeard360 like this.
  10. Smitty's32
    Smitty's32
    No, just 4 tabs on the clutches, trac loc style. One shim in the bottom, no Belleville.
  11. big duece
    big duece
    from kansas
    That looks like an aftermarket trac loc, OEM Ford carrier has two small countersink screws that hold the halfs together untill the ring gear is installed. ford-9-inch-28-spline-trac-lok-rebuild-spider-gears-centter-block-and-preloaded-plate-on-top.jpg
  12. Smitty's32
    Smitty's32
  13. Smitty's32
    Smitty's32
    The ring gear half is stamped C6AW 4205-B, and no it doesn't have the 2 screw holes. That's why I'm suspecting it was a regular Ford open that someone slapped on a trac loc big end thinking that would "convert it". But I don't know.
  14. Boneyard51
    Boneyard51
    Ford made an early and late traction enhancer that looked similar. Yours could be the earlier one….or not! The earlier ones used larger diameter clutch plates. Yours appears to be “ shiner” than most of the ones I encountered, so it also could be aftermarket , as mentioned!
    Bones
  15. big duece
    big duece
    from kansas
    My trac loc also has the C6AW 4205-B, looks cast in instead of stamped. thumbnail - 2022-12-05T203122.981.jpg
  16. big duece
    big duece
    from kansas
    Known open carrier on left, known trac loc on right. thumbnail - 2022-12-05T203118.259.jpg
  17. Smitty's32
    Smitty's32
    Great picture. Thanks! Different machining on the face shows me I don't have a standard carrier. So I'm back to not knowing what the hell I have. And why it has a donut between the spiders instead of a square block with springs.
  18. big duece
    big duece
    from kansas
  19. Smitty's32
    Smitty's32
    Side gear looks great. I've found the missing pieces online, I'd just like to be sure they will fit in that housing. I'm thinking now I have an older equa lock housing with an aftermarket trac loc end bolted to it.
