Ford 9"
Discussion in 'The Hokey Ass Message Board' started by SlowandLow63, Jan 12, 2007.
  1. SlowandLow63
    SlowandLow63
    from Central NJ
    Can someone please post a pic of the 3rd member head on and of the rear cover head on?? I'm having some doubts.
  2. TINGLER
    TINGLER
    If you are wondering is it an 8" or is it a 9", it's relatively easy to tell.
    For a 9" you can tell like this:
    When removing the 3rd member from the housing....On the bottom of the 3rd member under the pinion area there are a few nuts that you will have to remove with a wrench as you won't be able to get a socket on it.
    For an 8" those same nuts will be easily removed with a sock and ratchet.
    Of course when you have an 8 and a 9 side by side you can easily tell the difference as the 9 is physically larger.
  3. Never Die
    Never Die
    If it's ***embled, Tingler's method is the easiest/best as they look almost damn identical. If it's apart, measure the ring gear diameter... Pictures really won't do you MUCH good, they're are a **** load of different 3rd member housings and yokes available. I've had a few, and I **** you not never 2 of the same.
  4. dummy
    dummy
    from So. Cal
    Here ya go.
      100.8 KB
      92.2 KB
  5. jetmek
    jetmek
    lets not forget the oddball 9 1/4. that one tripped me up once
  6. joeybsyc
    joeybsyc
    from PA
    Any way to tell a 28 spline from a 31 without taking anything apart?
  7. Never Die
    Never Die
    Yep, look at the axle hubs. 28 spline have an hourgl*** sorta deal cast into them, the 31 spine has 3 round holes in a line.
  8. This is a 31 spline 9" with trac-loc and 3.50 gears. It came out of an older Bronco.
  9. I have found that the ends of the axles is not always true.....spline counting is the only 100% way to be sure.
  10. SlowandLow63
    SlowandLow63
    from Central NJ
    i can tell 9" from 8" by the back of the case, what im concerned is at a glance i was sure the rear in my 51 ford was swapped to a 9" already. however someone on here had posted a pic of a stock 51 ford rear, and from memory (the car is at my garage couple town over) that looked oddly familiar too. castings?? anything like that i can look for??
  11. mtflat
    mtflat
    IN your first post you mentioned wanting a pic of the rear cover. There is no rear cover on either 8" or 9" axles. If you have one on your '51 it's not a 9".
    If it was swapped it might be an 7.5/8.8
  12. SlowandLow63
    SlowandLow63
    from Central NJ
    i kno there isnt technically a rear cover on an 8" or 9", so ill say this a head on pic of the rear of the case.
  13. CharlieLed
    CharlieLed
    I had this same question some time ago and found this pic that I took showing how the socket won't fit onto the lower nut on the 9 inch chunk...
  14. Easier way to tell. 9" don't have a rear cover.
  15. SlowandLow63
    SlowandLow63
    from Central NJ
    ill take a pic of the rear in the 51 tomorrow and post it if i cant figure it out myself
  16. SlowandLow63
    SlowandLow63
    from Central NJ
    ya good thing i checked myself before i wrecked myself... stock rear, can we confirm??
  17. TINGLER
    TINGLER
    I have a rear end laying here that looks just like that.
    Its not a 9"......or an 8".
    I did not know what mine was.
    Guess I know now.
  18. Jalopy Joker
    Jalopy Joker
    See my post yesterday at 6:01 PM
    Ford Rear End/8"-9"/I.D.,Ratio,Width,Etc.
    Good Luck
