Technical ford 9in.
Discussion in 'Traditional Hot Rods' started by taters-truck, Jan 18, 2016.
  1. taters-truck
    taters-truck
    I have a 9in. unit that has 4 spyder gears and 3 pins and no place to put the posi steels so I guess it a open unit was told it to be a limited type has 31 spline and 1966 date code don't know what the rest of code is for . any help would be appreciated ... thanks ps have some pics if would help
  2. squirrel
    Yeah, pictures always help!
    The clutch plates on a 9 inch are on only one side of the differential, not both sides like most others.
    hipster likes this.
  3. Mike VV
    Mike VV
    from SoCal
    In todays world, there are MANY types of "posi" units out there.
    As has been said, in this case, a picture would help greatly.
    Mike
    hipster likes this.
  4. saltflats
    saltflats
    from Missouri
    They did make a 4 pinion open carrier for the 9 inch.
  5. All the factory posi carriers I have seen, have the ring gear bolts mounting surface machined and sunk into the carrier, the bolts on the open carriers are not sunk into it. If this makes any sense
  6. seb fontana
    seb fontana
    from ct
    Yes and in the 9-3/8 too...28 and 31 spline..
  7. Relic Stew
    Relic Stew
    from Wisconsin
    I'll add a picture. This is the easiest way to identify a factory limited slip.
    It also has the crack running around to all the bolt holes, which is quite common.
    Speedys Garage and loudbang like this.
  8. squirrel
    heh...that's why I don't have any of them to take pictures of! After fixing a couple for other people, I decided I never wanted to run one.
    Max Gearhead likes this.
  9. aaggie
    aaggie
    It really tests your pucker power when you are hooked up and just about to the 60' lights and that carrier decides to come apart.
    squirrel likes this.
  10. RmK57
    RmK57
    Looks like a machining mark to me.
  11. seb fontana
    seb fontana
    from ct
    The other pic..
  12. Relic Stew
    Relic Stew
    from Wisconsin
    Easier to see with the springs still in it.
  13. hipster
    hipster
    Yup, that's a factory piece. A lot of upgrades/replacements available that don't do that. Often.
    Think Strange, Currie, Moser, etc.
  14. DDDenny
    That must have been one drunk machinist.
    hipster likes this.
