Hey guys, I have a question. I drug my 53 victoria home yesterday. When i bought it the guy gave me a 93 302 ho with a aod to go with it. I am not a big fan of that style of fuel injection in older cars. So I am going to put a four barrel on it. Now here is the question. Can I make that aod work without the computer an fuel injection set up? Or I am i better off finding a wirring harness an compter an running the fuel injection? Thanks Don
93 might be wrong but i dont think that the aod in 93 was an aode, which is electronic. so if you dont want infection on it. put a carb and intake on it , get a tv cable kit from lokar and follow the instuctions closely. you should be good to go.
OKay cool I need to do some research on what ****** that actually is.I am not familiar with them at all. Sorry I am a converted chevy guy! But atleast I am coming around right?
well im a ford guy myself. ive got freinds the do the simple thing of chevy. i give people greif about it thats just my way about anything. but i say as long as your crusing your ride somehow its all good.
You are in luck! the '93 is the last year for the AOD non-computer transmissions and also has the best internal mods to make it live.When you get ready to do the swap send me a pm with your email address and I'll send you some pics of the Lokar linkage installed and some recommendations as to intakes and Carbs that will work best with it.You will want to swap out your existing timing cover for an earlier model with a provision for a manual pump mount also contact Todd(aka ct fortner) here to get the scoop on converting to the early timing chain and eccentric to work with the manual pump.
Wow thanks for the help guys!!! I havent had time to do anything to them today but i plan to pull the transmission off the engine tomarrow. Jeff I will deffinatly PM you! thanks guys I will keep you all posted
